Spanish 200 casing v Italian 200 casing
Postby Omega 7 » Mon Jan 19, 2015 9:35 am
Just in the middle of building an engine, the casing is a Spanish 200, is there anything differant between a Spanish & Italian casing.
Omega 7
Re: Spanish 200 casing v Italian 200 casing
Postby Knowledge » Mon Jan 19, 2015 10:02 am
Given a choice, I'd use a Spanish casing. Most Spanish stuff is better quality than the Innocenti original.
Postby NorthernJordan » Mon Jan 19, 2015 11:21 am
Depending on the year of the engine the Rear Shock mount may be longer and will potentially need spacing to align the shocker with the mount on the frame (if earlier Spanish or Italian frame).
And there maybe a neutral light switch in the gearbox. Mines just left in without being connected.
NorthernJordan
Postby St George » Tue Jan 20, 2015 4:29 pm
A few people who race go for the Spanish casing as they are apparently made better/stronger.
St George
Postby TS1-200 » Mon Jan 26, 2015 1:45 am
Also the deck height can be slightly different to an Italian casing, when I built my TS1 on a Spanish case I had to have an amount machined off of the face where the cylinder bolts on to, sorry can`t remember how much though.
TS1-200
