gaz_powell wrote:AF do it for £15
when i was looking for a piston for a TS1 200 they offered a standard asso 200 with the arc cut in and not a hole(s)
Captain Pugwash wrote:Very nicely done
Dazza wrote:Think I've got it now , based on all of the above, going to have a go myself rather than splash out on a new piston ( that's my get out of jail free card)
Thanks for all your help chaps and I will report on the outcome..whatever it may be
hullygully wrote:Put the piston back on your con-rod (minus the rings), slide your barrel down & mark/scribe the extremities of your inlet width onto your piston.
Take the piston back off & mark the centre line of the 2 scribed lines, then mark 2 more lines, 3mm either side of the centre line.
Then mark 2 more lines, one @ 18mm from the skirt upwards, the other 38mm upwards
You should now have 2 windows which you will have to radia the corners by probably 5mm
good luck
Users browsing this forum: No registered users and 55 guests
