Powder coat remove or paint over
Postby grumpar » Sun Jan 11, 2015 10:51 am
Anyone had experience of spraying over powder coat or is it best to remove it if so how
grumpar
Re: Powder coat remove or paint over
Postby coaster » Sun Jan 11, 2015 10:56 am
grumpar wrote:Anyone had experience of spraying over powder coat or is it best to remove it if so how
I have no personal experience of painting over powder coat but plenty of people have had frames blasted and powder coated to save on priming. Personally, if I was after a quality job I would want a decent primer in direct contact with the metal.
Postby dickie » Sun Jan 11, 2015 11:37 am
Take it off and prime properly for a good job.
Only one sensible method of removing it; get it blasted.
Postby grumpar » Sun Jan 11, 2015 11:47 am
Thanks for the reply personally i would agree i always etch prime , high build primer and finish with cellulose on frame and and panels that said i have no objections with powder coat on tanks tool boxes air boxes etc and in this case a set of forks which i think are better in powder coat. (Just my opinion)
At the moment i have a set of forks which need jigging and straightening so will need refinishing they have been blasted and powder coated.
so in this case i need to know can i rub down and spray over or take down to bare metal and start again and what takes it off cheers
grumpar
Postby coaster » Sun Jan 11, 2015 12:26 pm
In that case, rubbing down with wet & dry followed by primer and top coats should be fine I would think.
Postby Digger » Sun Jan 11, 2015 2:22 pm
If they need jigging they will likely be subjected to heat.
Digger
Postby HxPaul » Sun Jan 11, 2015 2:23 pm
dickie wrote:Take it off and prime properly for a good job.
Most blast companies wont touch something thats been powder coated.........to difficult to remove the powder coating through blasting.
Postby grumpar » Sun Jan 11, 2015 2:34 pm
So how do i get it off defiantly having them jigged so will need refinishing if i keep them but the Scomadi Stainless Steel forks are looking more and more promising at the moment :D :D
grumpar
Postby gaz_powell » Sun Jan 11, 2015 3:04 pm
I have my frames powder coated then the loop wet painted to match the scooter colour
I have done two this way and no problems - my painter has no issue with it - its flatted back then primed and painted
In my case it worked out fine as the internals etc are all black so I`m not fussed on the frame matching the panel work (only the loop).
If I wanted the inside of the frame to match the panelwork colour - I would maybe look at wet spraying it all
Gaz
PS Ive had powder coating taken off - they used a chemical dip first then blasted it
Postby grumpar » Sun Jan 11, 2015 3:58 pm
Thanks Gaz very helpful
grumpar
Postby foremanbob » Tue Jan 13, 2015 11:50 am
if its a small job that you're looking to remove powder coating from, then liberally applying Nitromors and sticking in a plastic bag for a week lets the stuff pretty much fall off.
foremanbob
Postby STFC » Wed Jan 14, 2015 9:44 pm
Agreed ... Nitromors will get it off (the older stuff is better if you can find any) or a decent paint stripper
STFC
Postby dickie » Wed Jan 14, 2015 10:31 pm
Come to Newcastle; we'll do anything for money up here. :oops:
I've had loads of powder coat blasted off.
Postby bjhart » Thu Jan 15, 2015 2:14 pm
agree, I have used paint stripper..it virtually falls off.
bjhart
Users browsing this forum: No registered users and 59 guests
