by garynonnah » Sat Jan 03, 2015 5:56 pm
fitted the fuel tank to my gp.....but cannot set it centrally...approx 1/4 in of ctr.
thing is its not original tank but s3 which i believed would be fine.
All straps and rubbers aligned?????????????
garynonnah on Sat Jan 03, 2015 9:00 pm, edited 1 time in total.
garynonnah
by HxPaul » Sat Jan 03, 2015 7:00 pm
Do you have any pictures ?
by garynonnah » Sat Jan 03, 2015 7:04 pm
will av to upload later....
garynonnah
by garynonnah » Sat Jan 03, 2015 8:44 pm
Photos of the fuel tank
garynonnah
by garynonnah » Sat Jan 03, 2015 8:45 pm
More pics
garynonnah
by garynonnah » Sat Jan 03, 2015 8:46 pm
Pics
garynonnah
by garynonnah » Sat Jan 03, 2015 8:47 pm
and the last one
garynonnah
by Tractorman » Sat Jan 03, 2015 9:11 pm
It could be the angle of the photo but the tank looks to be tilted backwards. If you slacken the straps and turn it anti-clockwise that would move the filler cap forward.
by gaz_powell » Sat Jan 03, 2015 9:18 pm
A S3 tank should fit a GP okay - years ago I never knew the difference and fitted whatever I could get hold of !
difficult to tell why from photos -they can be a pain.
Try slackening off the straps (but not completely) and centre it up - ask someone to hold it in place while you tighten it up evenly from side to side - then see how it starts to pull up.
it does look tilted backwards and again I cant see properly but have you missed the square rubbers that go on the seem
good luck and keep us informed
by sunrisemac » Sat Jan 03, 2015 9:22 pm
the rubbers and straps don't look central on the mounting lugs in the last pic
sunrisemac
by garynonnah » Sat Jan 03, 2015 9:40 pm
cheers guys....will slacken off and try to rotate fwd, prob need someone to hold in position and tighten up....looks like the missus will be helping....lol
garynonnah
by Wack » Sun Jan 04, 2015 11:31 am
I've found that WD40 etc on the rubbers helps to move the tank about as the rubbers grip too much to allow the tank to settle in position. There seems to be various positions as to where the strap trunnions go, my untouched import has the trunnions on the top of the tank and can only be got at by removing the airbox .
by peejay » Mon Jan 05, 2015 12:56 am
tank tightening can really be a pain at times and others just fall into place.
i think in this instance all you can do is slacken off a bit , centralise the tank and tighten evenly.
it is surprising how much a tank can move out of line by just a very slight overtightening of one strap
by garynonnah » Mon Jan 05, 2015 8:54 pm
cheers all....got it fitted in best position , fairly ctrl...will be ok....thnx for all advice
garynonnah
by Paul Slack » Wed Jan 07, 2015 9:50 am
You have some rubber blocks missing. The ones that slip over the edge rim. They are square with a slit in one side. Without them the strap will rub on the lip and create bare metal leading to an area prone to rusting easier. They must be fitted.
When done, make sure every single rubber and strap is in place before tightening as yours were not first time around. It should line up perfectly if you follow that.
This may help:
http://lambrettarestorations.blogspot.c ... -tank.html
Paul Slack
Users browsing this forum: No registered users and 56 guests
