sx 200 help needed hastings
Postby baroda26 » Thu Dec 25, 2014 8:19 pm
Anyone near Hastings can lend me a hand to finish my SX200 rebuild 60% done engine finished in the frame .
I seem to be hitting all sorts of little problems and have never done a rebuild before cables and electrics main problems
Cheers Bardoda
baroda26
Re: sx 200 help needed hastings
Postby coaster » Thu Dec 25, 2014 10:25 pm
Are you using Sticky's book? Just take each problem one step at a time and post your questions on here preferably with photos and you'd be amazed at the help you will get 8-)
Here to help ;)
Postby baroda26 » Fri Dec 26, 2014 1:33 pm
Hi Coaster
Yes I have got stickys book and its good
Its confidence I lack as its new to me
Will plod on hoping to have it finished for May 2015
Cheers Terry
baroda26
Postby Scooterlam » Fri Dec 26, 2014 2:16 pm
A lack of confidence can be a plus, you'll be sure to check more thoroughly.
Read stckys a number of times before starting a task , then when you do it it will make more sense.
Take your time and protect your paint. Don't force anything and if it's not going well stop and go back to it.
And above all enjoy it.
Ps you have an active club the Saxons, nice people.
Scooterlam
Postby garynonnah » Fri Jan 02, 2015 9:37 am
just see your msg.....im doing the same fella gp200 first time, just finnished engine,
but its like last guy said one bit at a time, patients....good luck and appy scootering
garynonnah
Postby Paul Slack » Wed Jan 07, 2015 9:56 am
Paul Slack
Postby baroda26 » Wed Jan 07, 2015 8:45 pm
Hi all who responded
Thanks for all the tips and encouragement and the information sent
I will plod on
Today I extracted the hub screws from the hubs front and rear in readiness for using the SIP tubeless wheels
This went well following stickys book and other information available and being careful
Learning from this
Do not powder coat hubs the coating is to thick hubs will require blasting and spray coating wasted effort and monies
If there is anyone around Hastings to support I am still here
Cheers All Terry
baroda26
Postby Nelly » Wed Jan 07, 2015 8:56 pm
I found the Scooter Restorations catalogue invaluable when I built my Lammy, this was before the publication of Sticky's book. The exploded diagrams are very useful.
These days, however, Sticky's book is the first reference for most things Lambretta.
Nelly
Postby Revvers » Thu Jan 08, 2015 1:59 pm
I quite like the Haynes manual too and cross reference both. Still needed help on here regarding my phbh carb though! Best source of info
Revvers
Postby baroda26 » Thu Jan 08, 2015 8:39 pm
Sorry revvers I am not that person hopefully someone may be able too help you soon
If not I have a mate who is into car and tuning likes carbs so what is the problem ~I will pass it on see if he can help
Terry
baroda26
Postby Revvers » Fri Jan 09, 2015 11:45 am
baroda26 wrote:Sorry revvers I am not that person hopefully someone may be able too help you soon
Terry
No it's ok mate, what I meant was that neither manual adequately describes how to set up a phbh carb and the lads on here helped me set mine
Revvers
Postby Noddabodder » Fri Jan 09, 2015 5:03 pm
Terry
I've lost track of this, who is after the help with the carb, Revvers or Baroda?
If you describe the top end set up and exhaust being used I'm sure assistance will come.
Noddabodder
Postby Revvers » Mon Jan 12, 2015 2:27 pm
I think I may have confused things here!! I just mentioned that I didn't think either book helped me with my carb set up, but people on here did!! Sorry!
Revvers
Users browsing this forum: No registered users and 155 guests
