bike grim wrote:On my Imola I re torqued after about 500miles from new and it needed it and then left it until after about another 2500 miles on the way back from IOW when had big air leak only to find the head nuts loose. As the Imola has the secondary nuts on the head it actually leaked at the base where I am not using base gasket( to obtain the right squish). I reckon if I had re torqued previously I would have got home..
nickw wrote: A quick search on google gives answers to this age old problem
Eden wrote:I run the engine up to temp 2 or 3 times with the head cowl off letting it cool each time then re-torque.
Storkfoot wrote:I have only ever used flat washers although I don't see a problem with wavy ones. I wouldn't consider using nordlocks as they can be a nightmare to get off and I wouldn't want to have to reck the thread of the stud to get them off.
I do re torque at around 100 miles or sooner. The only time I have ever had an issue where I really did need to re torque was on an alloy barrel. Ts1 and SR were no problem but v3 Mugello that was a different story. This was a few years back now. May have been to do with the barrel warping.
Users browsing this forum: No registered users and 82 guests
