engine numbers
engine numbers
Postby bazza3004 » Thu Dec 25, 2014 5:38 pm
Got an engine here that has no innocenti stamp on with the numbers:- 150Li 045774. Can anyone tell me anything about this eg what approx year it relates to (if possible).Thanks.
bazza3004
Re: engine numbers
Postby grumpar » Fri Dec 26, 2014 3:16 pm
Series 2 Eibar Li 150 (Winter model): built from 1964 - 1965 - frame numbers start around 040001 and run up to 052000+ As Spanish scooters had matching frame and engine numbers (mine has ) yours should fall into these years being 150Li 045774
grumpar
Re: engine numbers
Postby bazza3004 » Fri Dec 26, 2014 3:43 pm
Thanks for that i was told the scoot it came fròm was spanish. Cheers.
bazza3004
Re: engine numbers
Postby grumpar » Fri Dec 26, 2014 4:03 pm
check gearbox ratios if thinking of tuning
Li150 Spanish
" This gearbox has a massive gap between 3rd and 4th and I don't recommend it, change the box to Li150 Italian.
Definitely don't fit a 16 tooth sprocket!"
Never done anything with mine i know its the "bad one" so left it as standard it runs ok
grumpar
Re: engine numbers
Postby bazza3004 » Fri Dec 26, 2014 11:23 pm
Hi i pulled the gears and checked the ratios and there the same as i have in my imola motor ie Li 150 italian . Also double checked them with the gear ratio chart on mb site and that confirmed it. Thanks for the replies.
bazza3004
Users browsing this forum: No registered users and 9 guests
