Replacing crank and bearings.
Postby phil99 » Sat Dec 20, 2014 5:59 pm
Which is the prefered option when replacing crank and bearings.......
With the engine removed or insitu??
Its a Italian G P 200......any advice please.
phil99
Re: Replacing crank and bearings.
Postby coaster » Sat Dec 20, 2014 6:16 pm
Engine out, it will save a LOT of time and trouble imho.
Postby Toddy » Sat Dec 20, 2014 11:40 pm
Either way, but as coaster says out is what I would recommend
Postby MickYork » Sun Dec 21, 2014 10:44 am
Saw a lad do it with engine in place.......took him about 4 hours (with several T breaks !!) and he made it look easy.
Postby MK Monty » Sun Dec 21, 2014 12:46 pm
Get yourself a 1 piece rear brake cable. It makes dropping the engine so easy. Carb off and let it hang, 1 c clip on the gear linkage. 4 bolts holding the gear cables and pivot, Plug cap off. Wires from the stator, 1 nut on the rear brake adjuster, Shock and main bolt. You can leave your runner boards on to drop it but loosing at least one makes it easier to refit the engine but it can be done. 1/2 an hours work tops. Hardest thing is lifting the lump onto the bench complete with wheel and pipe.
MK Monty
Postby Donnie » Tue Dec 23, 2014 6:16 pm
Always with the engine in situ assuming you have a ramp.
If no ramp then yeah you have to suffer with engine out
Donnie
Postby Simon ELC » Wed Dec 24, 2014 12:48 am
Having a ramp is a godsend but working on an engine is so much easier on the bench. Especially for a bearing strip down. if you set the casing up with studs for the control cables etc and quick action back brake cable it will save you time in the long run. And it will stop the engine bar seizing if its regularly removed and copper greased.
Just my preferred method.
The other day I managed to persuade my wife to let me put a stripped and semi cleaned engine casing and mag housing in the new Bosh dishwasher. It came out a treat.
Bum sex was still denied me.
Simon ELC
Postby Simon ELC » Wed Dec 24, 2014 1:11 am
Eden wrote:out so you have a good excuse to change the cables when you put it back in :lol:
And clean all the shit from the back of the frame.
Simon ELC
Postby dickie » Wed Dec 24, 2014 5:34 am
Think yourself lucky. I couldn't sit down for a week after we tried it. But the strapon was a little larger than I'd anticipated
Postby Tony Hart » Wed Dec 24, 2014 10:18 am
:lol:
Tony Hart
Users browsing this forum: Majestic-12 [Bot] and 76 guests
