Yes i'm happy with it.
I think it could be tinkered with to improve the low down performance but i won't be doing that this year.
Are you at the AF do at the weekend ?
jonhunter wrote:MickYork wrote:I'm running a 30mm PHBH, Franspeed Race and MTech.....i did have a Variotronic but changed it for a BGM stator and the the MTech. I've just changed from 4:6 gearing (using a Franspeed Tourer) to 4:8 for
Is it running cleanly now? Ive got 30mm phbh, 120 main, 57 pilot, 40 slide x7 needle second clip down, franspeed race,
Af road 6 plate, bgm stater agusto 6000, seems go well
MickYork wrote:av266 seems to ring a bell.......will post if different.
MickYork wrote:Yes i'm happy with it.
jonhunter wrote:Mines running 35mm flatslide mikuni with a franspeed race and varitronic with a reinforced flywheel,4.8 gearing, the mikuni has really cleaned it up compared to the phbh that was on there.
Got to say im really pleased with this set up!!
MickYork wrote:jonhunter wrote:Mines running 35mm flatslide mikuni with a franspeed race and varitronic with a reinforced flywheel,4.8 gearing, the mikuni has really cleaned it up compared to the phbh that was on there.
Will be fitting a Mikuni on mine soon. What jets/settings are you using on the carb ?
