Carb problem
Re: Carb problem
Postby Rushy » Thu Aug 27, 2026 4:52 pm
Would I have to up the pilot from a 45 to a 50 put a 200 slide
Rushy
Re: Carb problem
Postby Rich Oswald » Thu Aug 27, 2026 6:15 pm
200 slide, yes, but pilot shouldn't affect much at nearly full throttle.
Re: Carb problem
Postby Rushy » Thu Aug 27, 2026 8:55 pm
What jets and slide would be a good starting point. I have lots jets and slides I'm getting a bit confused now
Rushy
Re: Carb problem
Postby Rich Oswald » Fri Aug 28, 2026 9:34 am
I can't really comment on that as you really need someone with a similar 175 set up to advise. My comments were just general set up adjustments for any set up.
Re: Carb problem
Postby hullygully » Fri Aug 28, 2026 11:15 am
start with a gp 200 setup, main jet start with a 132, gives you leaway to go 2-up or down 8-)
Re: Carb problem
Postby Rushy » Fri Aug 28, 2026 1:09 pm
Thank you i will give it a go and report back
Rushy
Return to Carburettors
Users browsing this forum: Bing [Bot] and 42 guests
