Carb problem
Re: Carb problem
Postby Wack » Fri Aug 07, 2026 7:49 pm
Obviously the plug is far too lean so I suggest firstly checking that the airbox hasn't been gutted, ie the swan neck removed as this will drastically alter the airflow and would need far bigger jets.Next is to try a 5899-1 as this has smaller air bleed holes so richens the mixture up even though the atomiser bore is slightly smaller than the 5899-2.Lastly.the motor could have an air leak.
Re: Carb problem
Postby Rushy » Sat Aug 08, 2026 1:31 pm
I've just done another plug chop 2nd gear uphill for 15 sec and it looks like it too weak. I think I will take my exhaust off and measure the bore Image
Rushy
Re: Carb problem
Postby Rushy » Sat Aug 08, 2026 2:31 pm
I've just done another chop and it looks like it too weak I will have to take the exhaust off and measure the bore Image
Rushy
Re: Carb problem
Postby Rushy » Sat Aug 08, 2026 2:35 pm
The swan neck has been removed
Rushy
Re: Carb problem
Postby Rich Oswald » Sat Aug 08, 2026 8:02 pm
It's advisable to do plug chops on an older, used plug. They give a far better picture of the mix.
Re: Carb problem
Postby Storkfoot » Sat Aug 08, 2026 8:39 pm
Rushy wrote:The swan neck has been removed
If the swan neck in the airbox has been removed and the scooter had a 130 main jet, there’s a good chance that it isn’t anywhere near standard. If it was mine, I’d take the cylinder off and find out what has been done to the top end. It may have just been rebored to a 175, it may be a kit of some description, or it may have had some tuning work done. You’ll be forever guessing if you don’t take the cylinder off.
Re: Carb problem
Postby Rushy » Sun Aug 09, 2026 8:40 am
I'm going to to take a deeper look at what's going on this week and I will get back. Thanks
Rushy
Re: Carb problem
Postby Rushy » Sun Aug 09, 2026 9:52 am
I've just taken the exhaust off and measured the bore and it 62mm. Dose it mean it's a 175
Rushy
Re: Carb problem
Postby Storkfoot » Sun Aug 09, 2026 10:43 am
Rushy wrote:I've just taken the exhaust off and measured the bore and it 62mm. Dose it mean it's a 175
Yes it does. It could be a rebore on the original barrel or an Indian conversion barrel. I’ve never checked the timings on one of the Indian barrels but I have heard that they can be a bit hit and miss. If the timings are alll over the place, it can be a struggle to jet the carburettor.
Please post some pictures of the outside of the barrel, showing exhaust and inlet and also some pictures inside the bore showing the ports inside.
Re: Carb problem
Postby Rushy » Sun Aug 09, 2026 4:07 pm
Here is the photo of the exhaust port. Image. I've managed to find an airbox with the swan neck still in so I am going to fit that and start from scratch and set up for a 175.
Rushy
Re: Carb problem
Postby hullygully » Mon Aug 10, 2026 9:37 am
I had a mick Abbey tuned cast iron 175, sh2/22 carb bored out to 25mm, ancillotti big bore, breathe sweet air filter, swan kneck removed & air box drilled out, jets & slide as gp200 & main jet of 132, timing set @ 19deg btdc.
Hope this helps Rushy
Re: Carb problem
Postby Rushy » Mon Aug 10, 2026 11:01 am
Brilliant I will give it a go it will be a good base line to start from. Cheers
Rushy
Re: Carb problem
Postby Rushy » Tue Aug 25, 2026 6:12 pm
Just done another plug chop what do you think Image
Rushy
Re: Carb problem
Postby Rushy » Tue Aug 25, 2026 8:01 pm
Rushy
Re: Carb problem
Postby Rich Oswald » Wed Aug 26, 2026 9:25 am
Still very slightly weak, imo.
Re: Carb problem
Postby Rushy » Thu Aug 27, 2026 1:35 am
That's with a 135 main 45 pilot
Rushy
Re: Carb problem
Postby Rich Oswald » Thu Aug 27, 2026 9:06 am
Rushy wrote:That's with a 135 main 45 pilot
At what throttle opening was the plug chop done?
Re: Carb problem
Postby Rushy » Thu Aug 27, 2026 1:03 pm
Just short of full throttle
Rushy
Re: Carb problem
Postby Rushy » Thu Aug 27, 2026 1:06 pm
I've just measured a spare Jetex 22mm and it has been bored out to 25mm I wondered if this would be better
Rushy
Re: Carb problem
Postby Rich Oswald » Thu Aug 27, 2026 3:31 pm
Rushy wrote:I've just measured a spare Jetex 22mm and it has been bored out to 25mm I wondered if this would be better
I think it would, i've had success with a bored out AF Jetex.
Return to Carburettors
Users browsing this forum: Bing [Bot] and 30 guests
