gear box shimming question, which shim
Postby ianjc » Fri May 15, 2026 11:51 am
I have replaced the rear hub bearing (worn bearing) and after rebuilding the gearbox the existing 2.2mm shim is too tight. it won't turn, and I can not get a feeler gauge under. The biggest shim I have in my collection under 2.2mm is 1.7mm which is giving a feeler gauge reading of 0.40mm which is above the 0.30mm. Can someone advise an ideal size of shim to buy. Thanks
ianjc
Re: gear box shimming question, which shim
Postby Fast n Furious » Fri May 15, 2026 4:40 pm
1.9mm would seem to be the one you want.
£5.00 at MB scooters.
Postby ianjc » Fri May 15, 2026 9:09 pm
Thanks that's what I was thinking
ianjc
