boring std carb
boring std carb
Postby Mikedale » Mon May 04, 2026 7:00 am
anyone have knowledge about boring out a std 22mil carb on a 200 engine?
did it work ok?
did it improve performance?
is there a richer atomiser to use?
i dont understand how it can make a difference for the better as the inlet manifold is the same bore - smaller diameter means faster velocity and am i right in thinking arbs work better with more flow
trying to keep std looks but possible tweaks....
Mikedale
Re: boring std carb
Postby Scooterslag » Mon May 04, 2026 10:28 am
Local bloke to me bored out a 22mm years ago to 26mm(?) if memory serves - it went ok by the atomiser kept falling out. It was a while ago so can’t remember all the details properly . Cheers Paul :)
Re: boring std carb
Postby Rich Oswald » Mon May 04, 2026 7:05 pm
Mikedale wrote:anyone have knowledge about boring out a std 22mil carb on a 200 engine?
did it work ok?
AF do Jetex 22mm carbs bored out to 26mm in case you didn't know.
Re: boring std carb
Postby Storkfoot » Mon May 04, 2026 7:55 pm
Scooterslag wrote:Local bloke to me bored out a 22mm years ago to 26mm(?) if memory serves - it went ok by the atomiser kept falling out. It was a while ago so can’t remember all the details properly . Cheers Paul :)
:P
That made me laugh
Re: boring std carb
Postby hullygully » Wed May 06, 2026 9:45 am
af's also bore the manifold mouth out too
Re: boring std carb
Postby Rich Oswald » Thu May 07, 2026 9:50 am
hullygully wrote:af's also bore the manifold mouth out too
Indeed they do.
