Daves Li resto
Re: Daves Li resto
Postby dave411 » Sun Dec 14, 2014 12:53 pm
Ok,will give it a bash tommorow and report back.Thanks.
dave411
Re: Daves Li resto
Postby dave411 » Mon Dec 15, 2014 7:28 pm
I am pleased to confirm that Dickie was correct.The hot air gun worked a treat.
dave411
Re: Daves Li resto
Postby dave411 » Mon Dec 15, 2014 7:31 pm
So now I need to remove all the studs,de grease it and take all the casings to the Aqua Blasters.
I have had the frame powder coated white,and will paint the outside bits blue,thats ready for collection.
Roll on Christmas Hols :P
dave411
Re: Daves Li resto
Postby dave411 » Mon Dec 15, 2014 7:32 pm
:oops: The lump hammer was just on the bench :lol: :lol: :lol:
dave411
Re: Daves Li resto
Postby dickie » Mon Dec 15, 2014 7:58 pm
[quote="dave411"]I am pleased to confirm that Dickie was correct.The hot air gun worked a treat.
How many songs did you use for timing?
Re: Daves Li resto
Postby dave411 » Mon Dec 15, 2014 8:03 pm
One,it worked a treat.
Any more tips ;)
dave411
Re: Daves Li resto
Postby dickie » Mon Dec 15, 2014 8:18 pm
Chadley wrote:If your Ancillotti exhaust is anything like the one I bought, then it lined up and fitted easily with no adjustment needed.
That is until I went to take to retract the stand...
It required this mod to one of the two U bend sections:
I've just trial-fitted my ancillotti on the bench this evening. Went on easy, but I have two questions:
1: How can I tell if mine will clear the stand without fitting when in the scooter?
2: What is this lug for in the pictures below?
Re: Daves Li resto
Postby Chadley » Mon Dec 15, 2014 8:46 pm
Question 2: Later casings had another mounting point:
Chadley
Re: Daves Li resto
Postby Nigel. S » Mon Dec 15, 2014 10:26 pm
Re paint: I rattle canned most of my rebuild using paint from Lambrettapaints.co.uk. Went on a treat.
Nigel. S
Re: Daves Li resto
Postby dave411 » Tue Dec 16, 2014 9:02 am
Any pics Nigel?
dave411
Re: Daves Li resto
Postby dickie » Tue Dec 16, 2014 11:18 am
Chadley wrote:Question 2: Later casings had another mounting point:
Thanks Chadley. I don't want to cut it off, nor do I want to bend it out the way as it's just a bit of a bodge.
Is there some magic bracket available from somewhere that anyone knows of that will rsolve this?
Sorry Dave, i htink I've just hijacked your thread - oh well.
Re: Daves Li resto
Postby dave411 » Tue Dec 16, 2014 12:16 pm
No,you carry on.Its all good info,for everyone :D
dave411
Re: Daves Li resto
Postby Tractorman » Tue Dec 16, 2014 12:40 pm
Nigel. S wrote:Re paint: I rattle canned most of my rebuild using paint from Lambrettapaints.co.uk. Went on a treat.
Fully agree, I used a can last year and it went on a treat.
Re: Daves Li resto
Postby dave411 » Tue Dec 16, 2014 1:43 pm
Did you have to buff it up afterwards?
dave411
Re: Daves Li resto
Postby Nigel. S » Tue Dec 16, 2014 7:20 pm
OK, you did ask.... :D
In various stages of rebuild, no particular order.
The frame/loop, forks, splashplate, toolbox door I got done professionally but my budget took a hit hence reverting to spraycans for the rest. Yeah, lots of cutting it back, polishing etc but worth the effort. Just be patient.
And finally.. I'm really sorry, I know I shouldn't, couldn't resist though.....
Nigel. S
Re: Daves Li resto
Postby halesworthlambretta » Tue Dec 16, 2014 8:16 pm
Superb work - after looking at your photo's I'm off for an evening in the workshop to crack on with my rebuild
halesworthlambretta
Re: Daves Li resto
Postby peejay » Wed Dec 17, 2014 1:13 am
hi Dave
any motor above 150cc really benefits from the extra underneath bracket fitted to later engines.
ideally you should remove the bracket and reverse it to fit the plain pillar that you will tap 8mm.
if you don't want to reposition the lug then just make up a spacer between the two which is not ideal but better than no fixing.
Re: Daves Li resto
Postby dave411 » Wed Dec 17, 2014 11:44 am
Hey Nige,that looks fantastic.Hope mine looks like that.Just out of interest,what colour blue have you used?
dave411
Re: Daves Li resto
Postby Rich Oswald » Wed Dec 17, 2014 12:26 pm
Simply superb!
Re: Daves Li resto
Postby dave411 » Wed Dec 17, 2014 12:41 pm
Even more so cause it was done with cans :P
dave411
Users browsing this forum: Baidu [Spider] and 58 guests
