Knowledge wrote: The video is 44 minutes long!
Adam_Winstone wrote:I look forward to trying these myself. They look like a great way to address the historic problem of poor rear brake on SIL casings.
Adam
al pushpak wrote:Hi all, bought one of these brake pin kits fairly recently which I must say arrived super quick in the post! So, armed with the instruction booklet that came with the kit & a brand new set of Makino brake shoes I set about fitting the pins this morning, all seemed fairly straight forward & I got both shoes set with them just touching the tool arm bolt, the bottom shoe touching slightly more so, but that was the best I could get it, unfortunately when it came to refitting the rear hub I found it was binding on the shoes after I tightened it down( I had slackened off the brake cable adjuster first before refitting the hub) so, removed the hub & started from the beginning again!! Tried again with the same result! ended up putting my old shoes back on & with the hub refitted all was fine ,so either my brake pin threads are really misaligned (SIL 200 casing) or my hub,which is a Uni one & only about 3 years old is slightly oval. Might have another go with it using a different set of shoes sometime in the future.....
Adam_Winstone wrote:FYI - I have also had a situation where aftermarket shoes were not the correct size to fit with either the early brake cam or later (GP type) cam, not allowing the hub to fit. This instance was a number of years ago so unrelated to your pin product but is worth considering if people are fitting new shoes, as suggested.
Obvs, if fitting new shoes, do make sure that they are the correct design for the motor's cam. A pal with a rebuilt motor in his GP swore blind that he needed GP shoes but an inspection revealed an Li/SX cam fitted!
Adam
gaz_powell wrote:Rich, if you are stuck you can borrow mine.
I bought a set but won't get round to fitting for a while...
All the feedback is beneficial!
dickie wrote:I ordered some without checking and presumed incorrectly that they'd come with the alignment tool.
Not back in stock for a while yet. So watch out as they're pretty useless unless you have the right tool.
Oh well.
Users browsing this forum: No registered users and 55 guests
