Vape ignition
Vape ignition
Postby jonoy » Sat Nov 01, 2025 1:37 pm
Does anyone that has a vape ignition find it takes several kicks to start from cold ?
jonoy
Re: Vape ignition
Postby avanti » Sun Nov 02, 2025 4:44 pm
HI , yes mine does static 18 BTDC , i put it down to the light flywheel ?
but wouldn't swear to it KTF
avanti
Re: Vape ignition
Postby Toddy » Sun Nov 09, 2025 6:32 pm
No mines 2 , 3 at the most usually
Re: Vape ignition
Postby bert one » Sat Nov 15, 2025 10:17 pm
jonoy wrote:Does anyone that has a vape ignition find it takes several kicks to start from cold ?
Yes, mine takes a good few kicks if not been started for a while, but 1st kick from warm/hot thereafter. I wondered if it's unspent fuel pooling in the rubber elbow of the Casa PowerFlow air filter fitted to a Dellorto PHBH 30mm. I have the elbow/filter fitted horizontally facing backwards due to the shape of my mid range tank, as it's the only position I can get it to retain its shape without it being squished underneath a Jet 200 panel.
I may try to fit a drain/breather tube to the rubber elbow to see if this helps with the cold starting.
Btw, the kit is an Avanti 225 (piston port), my timing is 17 degrees static with 1.5mm squish & Champion N3 plug.
Dellorto PHBH 30mm, 70 choke, 55 pilot, 40 slide.
bert one
