Installing points and Fibre Washers
Postby Paul_from_Thornbury » Fri Oct 17, 2025 3:57 pm
Refurbished a TV 175 engine for a guy here in Finland. Fitted new points. Can anyone advise correct position of fibre washers. Not fitted points for 40 years and I can’t locate information anywhere. I have a picture but when I’ve tried to load this post with a picture it doesn’t share, so I’ve left picture off.
Paul_from_Thornbury
Re: Installing points and Fibre Washers
Postby nsaints » Fri Oct 17, 2025 4:36 pm
Can't help with your question directly, but I think a picture would really help
So, use this site to load your picture onto. Then share the picture, here to the forum, using the 'Img' button when you create the post.
use the 'preview' button to check you have created your post with the image correctly and update if the picture doesn't appear. Maybe a bit of trial and error the 1st time
https://postimages.org/
nsaints
Postby Toddy » Fri Oct 17, 2025 5:59 pm
Here’s Paul’s photo
Users browsing this forum: Google [Bot] and 73 guests
