Soldering kit to rewire a stator.
Postby Storkfoot » Fri Sep 26, 2025 9:33 pm
For many years, I’ve survived on a Draper 20w soldering iron. It still works but as I need to completely rewire a stator plate, I have been looking online for a more powerful replacement.
My head’s frazzled looking at them all :!:
Can someone recommend one that will do what I need please?
Oh, and do I need one of those “solder sucker” devices or are they no better than the wick method of removing old solder?
Re: Soldering kit to rewire a stator.
Postby dickie » Sun Sep 28, 2025 8:35 am
Solder suckers are excellent, worth buying to do a nice job. I'll bet you can get one for peanuts on ebay etc
I'm not on the tools anymore, apart from occasionally,but when I was, I used one all the time.
I'd also recommend a brass brush to clean surafaces before soldering, oxidised copper can be a nightmare to solder.
https://share.google/w28TA3y2br4EyGsez
That's a bargain but you'll need change the plug to uk type.
Postby Storkfoot » Mon Sep 29, 2025 7:51 am
dickie wrote:Solder suckers are excellent, worth buying to do a nice job. I'll bet you can get one for peanuts on ebay etc
Thanks very much for that response. You are right that solder suckers are cheap on eBay :)
Postby al pushpak » Mon Sep 29, 2025 12:10 pm
Storkfoot wrote:For many years, I’ve survived on a Draper 20w soldering iron. It still works but as I need to completely rewire a stator plate, I have been looking online for a more powerful replacement.
We use the "Weller" brand soldering irons at work which are 90w & are perfect for repairing stator plates as I've repaired a couple of mine in the past using the work one's, & yes, a solder sucker is a good idea too.
al pushpak
Postby L111amo » Mon Sep 29, 2025 7:43 pm
I use a snap on gas pencil type soldering iron, never let me down
L111amo
Postby Fast n Furious » Wed Oct 01, 2025 6:03 pm
Likewise, I use my 40 year old Weller 90W iron for such purposes. A small iron isn't big enough and will likely create a dry joint. Always make sure that your iron tip is tinned up and your wires are perfectly clean. A little brick acid can help here. I would also recommend using some isopropyl alcohol to neutralise the solder flux remnants afterwards.
Postby Storkfoot » Fri Oct 03, 2025 7:25 am
Thanks for all the replies. I have ordered a cheap 90w set off eBay with temperature adjustment and solder sucker. Whilst I do use a soldering iron quite a bit, to trim cables mainly, I doubt I would get the use out of an expensive set.
I’ll let you know how I get on with the stator. The stator I am going to rewire has multiple exposed wires and looks pretty sorry for itself. However, yesterday I checked the readings and they are all good.
Postby gaz_powell » Sat Oct 04, 2025 8:20 am
Send me a link Paul, i need a new one
Postby Adam_Winstone » Sat Oct 04, 2025 9:50 am
Welcome to a new world of stator upgrade possibilities, from minor repairs to complete strips to bare laminate core and coil reconfiguration.
It's actually quite rewarding when a stator that you've reconfigured takes you around Europe without issue, especially if it does so for many seasons.
Stator rebuilds can bring you into a whole new sphere of 'dork', which is where I'm at (lol).
Postby Storkfoot » Sat Oct 04, 2025 2:24 pm
Baby steps first :D
Perhaps at this point, I should confess that this is an original Piaggio stator for a PX200E :o
Postby AlG » Sat Oct 04, 2025 3:17 pm
I have many miles using a reworked Vespa T5 stator on a Ducati baseplate.
Storkfoot wrote:Baby steps first :D
AlG
Postby Adam_Winstone » Sat Oct 04, 2025 5:21 pm
No shame in that, I also fix Vespa stators for clubmates, which happens more frequently as stators age and hit'n'miss pattern Vespa stators are failing frequently.
I also love stripping down original Ducati Vespa stators to use the pickups and LTs on Lambretta stators.
Postby coaster » Thu Oct 09, 2025 1:02 am
Its a good idea to anchor all wires with araldite or similar to prevent breakage, vibration is the enemy 8-)
Postby duncan1958 » Thu Oct 16, 2025 11:28 pm
I have an old Weller soldering iron that I've used to rebuild a few stators now.
Converting points stators to 12v DC using the coils from Scootronics.
External pick up and his universal CDI coil set up.
Also repaired a few BGM stators with either the low tension coil or pick up, again using Scootronics parts.
I've had that soldering iron since I was a young lad and that was a long time ago :)
duncan1958
Users browsing this forum: Google [Bot] and 52 guests
