Ex-Box Back in Stock
Postby nsaints » Fri Sep 12, 2025 5:27 pm
Heads up folks
Standard Ex-Box exhausts back in stock as of this afternoon
https://www.supertune.co/
nsaints
Re: Ex-Box Back in Stock
Postby gaz_powell » Mon Sep 15, 2025 3:51 pm
Having been behind one for a lot this year, including C2C... I dont want to see or hear another for a while
Postby Adam_Winstone » Mon Sep 15, 2025 8:04 pm
My non ST ExBox isn't too loud. Sure the ST needs the tail can IMO but the regular ExBox works for me... so much that I've bought a second one.
Don't get me wrong, they're louder than a number of other clubmans / Super clubmans but they also flow better and allow higher revving kits to work correctly, where some others strangle the revs before many kits come into the power.
Horses for courses.
Postby Toddy » Mon Sep 15, 2025 10:14 pm
Adam_Winstone wrote:My non ST ExBox isn't too loud. Sure the ST needs the tail can IMO but the regular ExBox works for me... so much that I've bought a second one.
Horses for courses.
Agree I have run both the ST with the muffler is loud but performs well I also run an Xbox on another engine and happy with it performance and noise wise
Postby Rich Oswald » Tue Sep 16, 2025 4:19 am
Horses for courses.
+1
Postby jonoy » Tue Sep 16, 2025 10:09 am
I have a ex box clubman and people have commented it’s very loud.
jonoy
Postby jonoy » Tue Apr 07, 2026 9:31 pm
Recently fitted an ex box st and find it quieter than the ex box
clubman.
Out today for first time and found kickstart side panel unclipped,GP.
I think it may have been caused by the end can.
Has anyone else had this issue ?
jonoy
Postby superhooper » Wed Apr 08, 2026 9:24 pm
The panel on my GP kept getting knocked off . I discovered that it was hitting the silencer bracket bolt. Your suspension may need hardening up as that is how i solved issue on mine.
Regards
Roy
superhooper
Postby jonoy » Thu Apr 09, 2026 11:08 am
superhooper wrote:The panel on my GP kept getting knocked off . I discovered that it was hitting the silencer bracket bolt. Your suspension may need hardening up as that is how i solved issue on mine.
Regards
Roy
Thank you for the reply.
I did that and went over a speed bump several times back and forth
and it appears to have resolved it.
jonoy
Postby jonoy » Sun Jun 21, 2026 11:44 am
Regards
Roy
Went to big 7 scooter rally and the silencer or mounting bracket caused the side panel to come off.
It’s an adjustable rear shock that I adjusted to its hardest setting after the last issue.
jonoy
Postby superhooper » Sun Jun 21, 2026 7:54 pm
In my opinion the bracket is positioned the wrong way round. If they were welded so that silencer bracket sat behind the casing one i think they would pass behind the side panel. Another local lad had the same problem, shame as they work well!
superhooper
