Ser 3 Scootopia Exhaust
Postby Paulusgnome » Thu Aug 28, 2025 8:50 am
Just bought the above, but it has a horizontal fixing plate that should bolt to underside of the gearbox, but I have nothing to fix it to, do I leave it or cut it off ?
Paulusgnome
Re: Ser 3 Scootopia Exhaust
Postby L111amo » Thu Aug 28, 2025 10:52 am
There should be a threaded hole underneath, possibly the bolt has broken off flush
L111amo
Postby nsaints » Thu Aug 28, 2025 11:15 am
it could also be that the engine is early enough that no hole under the crankcase was drilled/tapped by the factory
my series 3 TV175 never had an exhaust mounting hole
I think you can drill the hole and tap it with the risk of breaking through and creating a handy, but unwanted, auxiliary oil drain hole, or do as I did and chop the bracket off the exhaust
nsaints
Postby Paulusgnome » Thu Aug 28, 2025 12:06 pm
L111amo wrote:There should be a threaded hole underneath, possibly the bolt has broken off flush
no hole evident, thanks
Paulusgnome
Postby Paulusgnome » Thu Aug 28, 2025 12:07 pm
nsaints wrote:it could also be that the engine is early enough that no hole under the crankcase was drilled/tapped by the factory
thanks, i'll cut the bracket off , easier and safer solution .....
Paulusgnome
Postby Storkfoot » Thu Aug 28, 2025 12:18 pm
I’d just leave it on. It won’t do any harm and would be useful if the exhaust later gets fitted to another casing.
Postby nsaints » Thu Aug 28, 2025 1:21 pm
On the other hand I had a weird vibration with the bracket knocking unfastened against the bottom of the engine..
Off it came ;)
nsaints
Postby Toddy » Thu Aug 28, 2025 9:49 pm
+1
Postby Toddy » Mon Sep 01, 2025 7:10 am
Or you could do this
