Fast n Furious wrote:You might just need to run a colder plug? Worth a try!
Thackers wrote:Fast n Furious wrote:You might just need to run a colder plug? Worth a try!
Thank you that's something I'd not considered I was using a NGK 8 so I'll try a 9.
Thackers wrote:Thanks for the advice fellas
The kit is the casa ss225, with LI150 gears and a 46 x 15 crown wheel/ sprocket . 30mm dellorto TSR EVO pipe. All fairly common I would think.
Point taken regards plug brand and number, I'll go back to the 8 and look into changing brands for the equivalent.
Thanks again.
Fast n Furious wrote:Dave... can you be certain that your NGK plug is genuine? NGK is the most counterfeited plug brand out there!!!! Counterfeiters tend not to bother copying Champion or Denso.
Try using a Chamion N3 and see what difference it makes before pulling your hair out changing anything else.
alex_hughes wrote:I’ll be interested in how this pans out, please let us know.
For what it’s worth a club mate is suffering the same problem, my first thought was fake plug, but changing from NGK to Champion didn’t help him at all.
alex_hughes wrote:Well, an update on friends bike.
The first thought was fuel starvation and its turned out to be a longer than normal float needle getting wedged as the float bowl emptied on full throttle, and so not letting enough fuel flow. At less than full throttle the bike rode fine, witnessed by a medium/slow ride to the 5N rally in Northern Ireland. (great rally, BTW)
Thanks must go to Adam Winstone, our club mate with the determination to get to the bottom of this one. Top man, as always.
Thackers wrote:alex_hughes wrote:Well, an update on friends bike.
Good result and great detective work![]()
Users browsing this forum: No registered users and 48 guests
