L111amo wrote:Got a bgm stator on my gp, been on for 14 years, never missed a beat, IOW 7 times, Trance 2 times & Belgium once pls loads of the usual rallies, Donno if I’m just lucky, wished I hadn’t said anything now
dickie wrote:Pete, thanks for that informed response.
Why do you say that pick-ups are wrongly blamed? I know that in this sort of diagnosis, a lot of guesswork takes place and in the end the wrong thing is disgnosed among a pile of parts changed just to check. But, there does seem to be a good number of BGM ones failing at the moment.
I'm curious as to what a pick up actually is though? Is it just a coil, or what?
Interesting what you say about Reedspeed CDIs having a strong spark at kickover. My DC ignition is weak on kickover as it also has to charge a 10000 microfarad capacitor that i have on the DC output. I tried putting a 13V power supply on to mimic a battery and the difference was amazing. I don't want to fit a switch, just so that i can keep original looks, so I'm building a little PCB to hide inside the junction box. But i also need to find somewhere to hide a small battery. The smallest i can find is 1.2Ah alarm battery.
dickie wrote:
And always nice to hear mention of Sean even though he did make a shit cuppa; too much milk every time.
gaz_powell wrote:When AF stopped doing the ducati electric kit, SR started offering a geniune SIL kit... SiL stator rewired by SR to vespa colours, a genuine SIL flywheel, ducati cdi and regulator. SR skimmed the long fins to standard height... mines been in for over 25yrs and been used.
Flywheel has been lightened since original installed and its been rewired as the cables got hard.. Still has same pick up and LT and has had one cdi change (replaced with ducati).
The engines had three cranks, several bearing replacements and its in its second TS top end.
Several years later another build same kit from SR.... Thats had 1 pick, 1 LT and a regulator swap, in 20yrs and its been well used. The failures in last 5 yrs.. And one rewire. Engines had three lits of bearing through it.
Those first kits as said were spot on.
I still use genuine SIL stators and flywheels with ducati cdi and regulators.... Wont change, last pick up and LT swaps were genuine piaggio still going strong.
This post will be the ultimate kiss of death!!!
gaz_powell wrote:The kiss of death was true... homeward from Ayr
Though it was a wiring issue on the stator that was the problem...and it did have a lot of miles on it and no known history before it went on.
Rebuilt SIL going on this weekend.....
Micky67keane wrote:A long time waiting for recovery last night after a suspected failed LT coil(replaced cdi,ht lead etc,no joy),its got me wondering about the Lukas cdi unit.Ive been fortunate to win a Vape ignition and was wondering if the Vape system uses a separate LT coil as in my Scootronics type stator.
If so I'd be better fitting a Lukas cdi rather than the Vape if the same thing could happen.Any help and advice would be greatly appreciated.Cheers
