scootopia manifold clearance
Postby shamrockexpress » Wed Feb 05, 2025 11:06 am
Tried fitting a jetex 22 onto a scootopia 22 manifold (small block spacing on inlet) and theres no room as its too close to the engine mount???? The cylinder is alloy iron liner small block 200 kit(196cc) is it the scootopia manifold at fault or inlet position on cylinder.......any ideas/ solutions be welcome.
thanks
shamrockexpress
Re: scootopia manifold clearance
Postby st3veallan » Fri Apr 25, 2025 6:54 pm
Depending how close it is to engine mounting is it possible to elongate the back hole on the manifold to swing it away s bit ?
st3veallan
Postby shamrockexpress » Sun Apr 27, 2025 10:51 pm
st3veallan wrote:Depending how close it is to engine mounting is it possible to elongate the back hole on the manifold to swing it away s bit ?
Thats exactly what i done,
thanks for the reply.
shamrockexpress
