Martian red.
Martian red.
Postby Psychedelicropcircle » Fri Mar 14, 2025 9:40 am
Have a feeling this is a controversial subject :lol:
Is there a ral code for this paint?
I need to paint over a replacement frame strut which isn’t seen although I’d like to get it right.
Ideally a rattle can would suffice.
Re: Martian red.
Postby Storkfoot » Fri Mar 14, 2025 8:05 pm
Jason at Absolutely had a code. I used that to paint a Vega.
I also got a red GP repainted. The Lechler paint suppliers matched it by eye to a Jaguar paint. They showed me before they mixed it and it was very close to, if not exactly the same as, the original orangey red. I think it was called Jaguar Photon red, from memory.
Re: Martian red.
Postby nastro azzurro » Sat Mar 15, 2025 9:51 am
Why don’t you buy a touch up pen in photon red to try?
Only about £10 on Amazon.
nastro azzurro
Re: Martian red.
Postby Adam_Winstone » Sat Mar 15, 2025 7:52 pm
Jason used the correct formula provided by Humberside Paints; the UK Lechler dealer that helped me get a match for my original paint sample that I sent him, which was on support of my Scootering feature that I wrote many years ago.
The often quoted 8073 code is not a match for a single original paint example to date, although all of the original example match each other; no coincidence. The chap at Lechler said that, "8073 clearly wasn't, and never had been, a match for the factory Martian Red."
If you do a search on the subject, the formula has been readily posted on various FB forums.... and probably on here too over the years.
I would post it again but don't have it to hand.
Re: Martian red.
Postby Toddy » Sat Mar 15, 2025 8:10 pm
Adam_Winstone wrote:Jason used the correct formula provided by Humberside Paints; the UK Lechler dealer that helped me get a match for my original paint sample that I sent him, which was on support of my Scootering feature that I wrote many years ago.
Humberside !!!! Wash your mouth out :lol: :lol:
Re: Martian red.
Postby Adam_Winstone » Sat Mar 15, 2025 9:21 pm
:lol:
Re: Martian red.
Postby Storkfoot » Sat Mar 15, 2025 9:58 pm
I know it’s almost impossible to tell from photos and it also matters what colour undercoat is used but:
Re: Martian red.
Postby Adam_Winstone » Sat Mar 15, 2025 11:15 pm
Yep, Humberside Paints sprayed test cards with different primer colours (wht, yellow, red oxide and grey) and then numbers of coats too.
They settled on grey primer, a certain number of coats and their own formular, which ended up being a very good match. A change to any of these factors would throw out the final match.
Re: Martian red.
Postby Rich Oswald » Sun Mar 16, 2025 12:17 pm
Ah, North Lincolnshire then! :lol:
Re: Martian red.
Postby Psychedelicropcircle » Wed Mar 19, 2025 6:11 pm
Thanks people I have ordered the photon paint in a rattle can. I’ll do a few coats of grey primer.
Users browsing this forum: Google [Bot] and 85 guests
