VHSH 30mm
VHSH 30mm
Postby B1gD0gu3 » Wed Mar 05, 2025 12:26 pm
Hi all,
Have recently fitted a VHSH 30mm to my TS1 225. Anyone with any experience of this carb advise on the carbs current set up:
U16 needle
155 Main jet
DQ 268 Atomiser
60 Pilot
50 Slide
300 Needle Vv
Franspeed Supertourer exhaust.
Running without side panel fitted but will be fitting once a hole is made in it.
I have changed the Main jet from 165 as it was very boggy, and replaced the DP 266 Atomiser for the DQ one. I haven't had chance to try out the changes made yet, just after people with far more knowledge of carb set ups than I have to give their opinions/advice.
Thanks in advance for any help/advice received.
B1gD0gu3
Re: VHSH 30mm
Postby hullygully » Wed Mar 05, 2025 1:46 pm
Whats the jet above the pilot?
is it a CD1 or a B**?
Re: VHSH 30mm
Postby Adam_Winstone » Wed Mar 05, 2025 2:44 pm
B1gD0gu3 wrote:Hi all,
U16 needle
155 Main jet
DQ 268 Atomiser
60 Pilot
50 Slide
300 Needle Vv
FYI - Most people that I know to be running actually use the K needle range in their VHSH carbs. I did similar with my VHSA carb, which is also intended for U-needle use, and I've ridden a fair few TS1s set up with K-needles and they've all been excellent. Whilst the U needles are shorter than the Ks, with some dealers/tuners suggesting that you should cut Ks to U length, this has never actually added any benefit and everyone that I know is still running full length needles in their VHSH. Not in a TS1 but I have had one of the UK's most respected dyno operators dyno my VHSH with full length Ks.
Are you particularly set on using U needles (fewer options than the extended K range)?
PS - Having spent a lot of time using VHSH, VHSA and VHSB carbs, I have noted VERY different set-up suggestions from others, with main jets differing wildly (i.e. 135-175). Indeed, whilst AF's recommendations are often around the 165 mark, I know of plenty of people leaving dynos with mains around 140-145. Perhaps this is a reflection of your richness with your current main, and you might want to look at other needle and atomiser options. BTW - I would consider the price of a decent dyno session vs the rapidly mounting cost of buying VHSH components to try.
Good luck getting it sorted.
Re: VHSH 30mm
Postby B1gD0gu3 » Wed Mar 05, 2025 3:18 pm
hullygully wrote:Whats the jet above the pilot?
It's a B
B1gD0gu3
Re: VHSH 30mm
Postby B1gD0gu3 » Wed Mar 05, 2025 5:58 pm
Adam_Winstone wrote:FYI - Most people that I know to be running actually use the K needle range in their VHSH carbs. I did similar with my VHSA carb, which is also intended for U-needle use, and I've ridden a fair few TS1s set up with K-needles and they've all been excellent. Whilst the U needles are shorter than the Ks, with some dealers/tuners suggesting that you should cut Ks to U length, this has never actually added any benefit and everyone that I know is still running full length needles in their VHSH. Not in a TS1 but I have had one of the UK's most respected dyno operators dyno my VHSH with full length Ks.
Thanks for the reply, appreciated.
I'm using the U16 needle as it was supplied in the carb. I am quite happy to change to a K needle, do you have any suggestions in which to try?
I totally agree about dynoing but I would have to van or trailer the scoot down South as there are no specialists up here in Scotland afaik with the facilities.
B1gD0gu3
Re: VHSH 30mm
Postby Toddy » Wed Mar 05, 2025 6:59 pm
Is hutchi and son performance anywhere near heard good reports on dynos and tuning
Re: VHSH 30mm
Postby B1gD0gu3 » Wed Mar 05, 2025 7:59 pm
I never even knew they existed, thank you very much for that! I will check them out. :D
B1gD0gu3
Re: VHSH 30mm
Postby Toddy » Wed Mar 05, 2025 8:00 pm
B1gD0gu3 wrote:I never even knew they existed, thank you very much for that! I will check them out. :D
No worries, good luck, he has a Facebook page as well if you do social media
Re: VHSH 30mm
Postby B1gD0gu3 » Thu Mar 06, 2025 8:50 pm
Have been in touch with them today, seems very knowledgeable and a genuine person. Am taking the scoot over to get it set up on the dyno. Will post results once i've got it sorted.
Thanks for the replies, appreciated & thank you Toddy for finding the place, 40minutes away & I didn't know it existed! :oops:
B1gD0gu3
Re: VHSH 30mm
Postby Toddy » Thu Mar 06, 2025 8:51 pm
B1gD0gu3 wrote:Have been in touch with them today, seems very knowledgeable and a genuine person. Am taking the scoot over to get it set up on the dyno. Will post results once i've got it sorted.
Nice one hope you get sorted ok buddy
Re: VHSH 30mm
Postby B1gD0gu3 » Mon Apr 07, 2025 6:44 pm
Well it didn't go too well, made 15hp on the dyno, jetting was sorted but issues abound. Engine was opened up and multiple faults found wrt engine build. Had no go whatsoever. So a rebuild is in order to put right some of the problems found. Was more annoyed that my season is over before it has begun. If anyone is interested I will update once everything is rectified. Thanks for all the help, it's appreciated.
B1gD0gu3
Re: VHSH 30mm
Postby Topgearskin » Mon Apr 14, 2025 11:00 am
interested to know what was flagged up in terms of the engine internals - keep us informed
Topgearskin
Re: VHSH 30mm
Postby Adam_Winstone » Mon Apr 14, 2025 1:30 pm
B1gD0gu3 wrote:Well it didn't go too well, made 15hp on the dyno, jetting was sorted but issues abound. Engine was opened up and multiple faults found wrt engine build. Had no go whatsoever. So a rebuild is in order to put right some of the problems found. Was more annoyed that my season is over before it has begun. If anyone is interested I will update once everything is rectified. Thanks for all the help, it's appreciated.
Bugger! Then again, you could have been chasing your tail, thinking that the issues were carb related, wasting time and money by looking in the other direction. In that respect, finding the issues means that the dyno session was quite a success.
All the best. I look forward to reading that all gets resolved and that you're happy with the end result.
Re: VHSH 30mm
Postby B1gD0gu3 » Sat Jul 25, 2026 12:15 am
Just an update on this.
After stripping the engine down a lot of issues were found with the build, so much in fact that the majority of the internals were of no use & had to be binned! A very expensive lesson learnt.
So after discussions with Craig Hutchison (Hutchi & Son) and deciding what I wanted from the engine a way ahead was agreed, a Touring Torque Monster! 8-) a few tweaks still to be made but we're almost there.
Spec wise:
Barrel replated
AF 5 speed box
AF 6 plate cassette clutch
Wossner Forged piston
Vape ignition
30mm PHBH
CST 3 exhaust
Mammoth head
TT Lhs carb manifold
Set up on Craigs dyno & it's making just under 27hp at 5712rpm and just shy of 26lbft at 5508rpm, with 20lbft available from 3600rpm.
Thanks to Toddy for linking me to Hutchi & Sons place, and I can't thank or praise Craig highly enough. Kept me updated through the whole process and is a genuinely nice guy who knows his stuff & is a true perfectionist.
Hopefully won't be too long before I have what I wanted originally.
Sorry for the long post.
B1gD0gu3
Re: VHSH 30mm
Postby shamrockexpress » Sat Jul 25, 2026 10:39 am
Sometimes it pays to shop local :D
why did you change carbs back to phbh?
shamrockexpress
Re: VHSH 30mm
Postby nickw » Sat Jul 25, 2026 10:39 am
Thanks for the update. Good to see a positive outcome although an expensive one :-)
nickw
Re: VHSH 30mm
Postby corrado » Sun Jul 26, 2026 1:29 am
B1gD0gu3 wrote: Touring Torque Monster! 8-)
Now that's what you call a Torque monster. Great work from Craig.
corrado
Re: VHSH 30mm
Postby ULC Soulagent » Sun Sep 06, 2026 12:57 pm
Feckin very expensive rebuild but glad ur sorted ;) myself have only used a dyno session twice in setting up carbs :D 1st one went bang around 146 miles after it. 2nd one using vhsh on my proddy scoot which went well over two seasons :D
ULC Soulagent
Re: VHSH 30mm
Postby B1gD0gu3 » Sun Sep 06, 2026 11:51 pm
shamrockexpress wrote:Sometimes it pays to shop local :D
Basically Craig has had really good results with them, he thinks they are superb & they are underated carb.
B1gD0gu3
Re: VHSH 30mm
Postby B1gD0gu3 » Sun Sep 06, 2026 11:56 pm
ULC Soulagent wrote:Feckin very expensive rebuild but glad ur sorted ;) myself have only used a dyno session twice in setting up carbs :D 1st one went bang around 146 miles after it. 2nd one using vhsh on my proddy scoot which went well over two seasons :D
Thanks 8-) You're right, it was a very expensive lesson to learn, sorted now though :D
B1gD0gu3
Return to Carburettors
Users browsing this forum: No registered users and 52 guests
