It’s probably just me, but anything that reduces the likelihood of an accident is best
Warkton Tornado No.1 wrote:Good idea with the ratchet strap but……..Maybe a better, safer method with the ratchet strap would be to hook into the fork top & the link. If the hook won’t fit the link, the strap itself should fit, then hook the strap itself![]()
Storkfoot wrote:I am interested in whether the 9mm bearings make a positive difference to the actuator. I never thought of that when I rebuilt the ones I did, one of which had quite a weak spring.
This may be of use to you, Mark:
viewtopic.php?f=10&t=12767&hilit=Actuator
Vegansydney was a great help.
dickie wrote:Larger ball-bearings will only increase the preload on the actuator spring. This will help the lever to return after operation but won't increase the pad movement or force.
Warkton Tornado No.1 wrote:Hmmm. Actually, the bigger balls will give greater movement for the same angle of lever movement. That’s not to say I have any experience or knowledge as to whether the modification is worthwhile
Adam_Winstone wrote:Getting any miles on this yet Marky? I want to know if it is putting a smile on your face yet
dickie wrote:I did try this a couple of years ago and it made no difference. Then I sat back and wondered why. It's pretty obvious when you think about it, that the movement rate is only affected by the angle of the 'cups' that they sit in. If you move those surfaces apart before you move them, it doesn't change the rate, only the starting point. This is nearly the same as adjusting the static pad.
I wasn't completely convinced so I modelled it in autocad to prove it to myself. When I get to work later I'll do it again and post the results on here.
I know it's intuitively correct, but in reality it does nothing.
13th Feb 7 by KTM Marky, on FlickrN Users browsing this forum: No registered users and 100 guests
