shamrockexpress wrote:I always had simlar symptons, after chatting to Ben at AF he pointed me towards the 8000 Motul oil i was using it turns out some of the race pre mix oils are very heavy and unless thoroughly mixed in a jar like at the racing, then they are likely to sink straight to the outlet in your fuel tap hence not mixing with the petrol until it has swished about the tank for a good while........
so i always had plooms of white smoke and lean running after filling with fuel, so the carb was getting a helping of 2 stroke and little petrol, solution was to make sure and always run injector oils instead of pre-mix!!!!![]()
To note pre-mix has about 10% more lube than injector but only when properly mixed which aint possible in a tank.....not saying this is the case with all pre-mix oils but it was a problem with the motul 8000.
Maybe nowt to do with your issue but something to note.
Adam_Winstone wrote:Potentially going in the wrong direction for your problem but on the topic of oils, years ago I got a deal on a load of bottles of competition grade Rockoil premix, which worked perfectly when I bought it. However, as soon as the season changed and we had a couple of cold mornings, I ran into problems! Basically, every time we had a cold night the oil would separate and fall out of suspension, leaving a thick sludge in the bottom of tank and float bowl, requiring a strip down each time. Whilst the oil may have been ideal for warm weather competition, with fuel being mixed / vigorously shaken before a race, it was completely useless for general use.
I'll revisit the initial issue now...
Adam_Winstone wrote:My thoughts on initial query...
DO NOT ASSUME THAT THE FUEL YOU BOUGHT IS NOT THE PROBLEM!!!
As you immediately ran into problems post-fill up, with plumes of white smoke, this is exactly what I and others have experienced a number of times after filling up with contaminated fuel, typically contaminated from the pump (big name stations too!) and assumed to be diesel contamination.
An easy check is to empty the float bowl and fill from a different/new source. FYI - When I did this for a friend, it took a couple of kicks to start, then billowed white smoke (unburnt fuel in exhaust) then ran clean but started to die as float bowl emptied. We then flicked back on the fuel tap and the engine went from running well to lumpy and died quickly after. Draining the tank and refilling cured it, after we had stripped the float bowl again![]()
A new issue so quickly after a refill... don't assume all is well.
coaster wrote:You don't half have some interesting problem Paul![]()
Re the seal if it wont let air out which is thin, it shouldn't let oil in which is thickand blocking the tail pipe ight not cause enough back pressure to stall the engine as slip joints are not airtight.
Storkfoot wrote:shamrockexpress wrote:I always had simlar symptons, after chatting to Ben at AF he pointed me towards the 8000 Motul oil i was using it turns out some of the race pre mix oils are very heavy and unless thoroughly mixed in a jar like at the racing, then they are likely to sink straight to the outlet in your fuel tap hence not mixing with the petrol until it has swished about the tank for a good while........
That is really interesting. I am not using Motul 8000 but I did think that the petrol colour in my petrol pipe was rather red tinged (the oil is red). I have been using this oil but not for very long![]()
Thanks for the reply.
I may still have a drive side oil seal that is blown mind. The engine definitely kept running, albeit badly, when I blocked the tailpipe.
Adam_Winstone wrote:Don't try to identify or test the fuel, substitute at least a float boel's worth with different source new fuel. It is a very easy, quick and cheap test... takes about the same time as writing a reply.
You could easily be confusing 2 separate issues. Notdoig this simple test now misses out on a valuable opportunity... at least to rule it out.
Fast n Furious wrote:Get a party balloon and fit it over your chaincase breather.
Start the engine. If it pumps the balloon, then you likely have seal or halite washer problems.
