Adam_Winstone wrote:Watch out for longer shocks causing frame to carb / manifold clearance issues. Many engine configurations cause issue, which is why you can find lots of info online about eccentric / offset engine bolt cones. Fitting a long shock just makes this potential problem worse.
gizmo wrote:The BGM rear shock is adjustable anyway so you can experiment with height
. The BGM one is adjustable from 300-310 mm in heightLambrettaMarky wrote:gizmo wrote:The BGM rear shock is adjustable anyway so you can experiment with height
Both the BGM & Pro Tech are adjustable for pre-load/sag, but I didn't think they had an adjustable ride height?
I'll give Pro Tech a call.
Thx.
gizmo wrote:. The BGM one is adjustable from 300-310 mm in heightLambrettaMarky wrote:gizmo wrote:The BGM rear shock is adjustable anyway so you can experiment with height
Thx.
protech inners by KTM Marky, on Flickr
protech goodies by KTM Marky, on FlickrLambrettaMarky wrote:Had a fun day today. 286 mile round trip on the GS down to see Tim @ protech. Sunshine, dry roads & it's mid November.
This is what's inside the rear shock and while I was there, got a quick look around their compact unit. The quality of the engineering is excellent as is the attention given to each & every unit build.protech inners by KTM Marky, on Flickr
I made off with the suspension for my GP and a heap of stickers:protech goodies by KTM Marky, on Flickr
Will repost back on the suspension, but it just has to be an improvement on India's finest!
LambrettaMarky wrote:SIL GP 200 - Is that the same fitment?
Storkfoot wrote:Mark, as an aside to whether these dampers are too wide to fit, how do you have your dampers attached? Are mounts welded top and bottom?
LambrettaMarky wrote:Storkfoot wrote:Mark, as an aside to whether these dampers are too wide to fit, how do you have your dampers attached? Are mounts welded top and bottom?
Yes Paul. I have the top bracket in place and the bracket for the lower mount attaches to the spindle/disc link. It had dampers on before, just that they were a bit rubbish.
The protech units are handed too courtesy of their offset mounts.
Users browsing this forum: Google [Bot] and 86 guests
