Storkfoot wrote:Until the last year or so, I’d have agreed with WT about the 270 on either a PHBL or PHBH. But, I have a Casa 192 with a PHBL25 and a standard mushroomless GP200 exhaust. I think the salient point with my attempts at jetting it was the fact that it didn’t like a 40 slide, it liked a 45. I ended with 48 pilot; D29/2; AQ270: Main 100. I even went to the added expense of buying an AQ269 but, no, it ran weak at one point in the mid range.
My TS1225 runs a PHBH30 with an AV268, whilst my Stage 4 200 (PHBL25) didn’t like the 45 slide/ AQ270, it runs a 40 slide and AQ266.
roli150lam wrote:ebay yes you could take the chance.
Storkfoot wrote:roli150lam wrote:ebay yes you could take the chance.
Mark, I’ll vouch for Wasp that they sell genuine Dell’orto parts. Avoid eBay unless you have to, in my opinion.
https://www.wasp-performance.co.uk/dell ... av268.html
Adam_Winstone wrote:Storkfoot wrote:Until the last year or so, I’d have agreed with WT about the 270 on either a PHBL or PHBH. But, I have a Casa 192 with a PHBL25 and a standard mushroomless GP200 exhaust. I think the salient point with my attempts at jetting it was the fact that it didn’t like a 40 slide, it liked a 45. I ended with 48 pilot; D29/2; AQ270: Main 100. I even went to the added expense of buying an AQ269 but, no, it ran weak at one point in the mid range.
One thing to note from the comments re: atomiser requirements for different carb types is that the body type and size is a variable... and to note that we're coming back with different size recommendations for each.
There are plenty of existing threads about how reed induction motors often require a slightly bigger atomiser than when using the same size/type carb on a piston port motor; e.g. AV266 (X7 needle) use is typical for a 30mm PHBH with piston port but AV268 (X13 or X2) is fairly common with the same sized reed motor. However, there seems to be little info out there re: influence of venturi size or body type.
I have been so impressed with a 24 PHBL on my iron 'Baby 200' in recent years, using it as a general 'go to' bike and the last 3 Euros + 1 x 5-Nations, that I opted to use a PHBL 25mm for my reed Rapido 225 that I built for this year's 5-Nations, with a balance of touring performance and fuel economy in mind. However, I was really surprised to find that my throttle position checks (including tests with the main jet out to ensure no restriction at partial throttle openings) was telling me that it was very weak through the mid range. I spent a lot of time testing to ensure that it was right for the 1200+ mile trip that I was about to take this new motor on and everything was pointing to the AQ266 atomiser being too weak. Thankfully the PHBL has single steps, rather than double, so I was able to source a AQ267, AQ268, AQ269 and AQ270 as well as already having a range of needles, jets and slides from setting up the 24 on other motor. Try as I might, I could not use a richer slide and leaner atomiser, found that a 45 slide and AQ268 was useable but still lean mid range, ending up on an AQ270 with 50 slide giving good test returns at all throttle positions. This bike then covered 1200+ miles without issue and not having the plug out once (plenty of checks done prior to leaving).
Interestingly, whilst my pre-5-Nations testing had led me to my own 'richer atomiser required' conclusion, this was not being reflected in the returns that I was getting from searching the web for PHBL setups... HOWEVER, that was until I stumbled across an older thread by a respected dealer of the day stating that they had found that the reed smallblock kits that they were a main agent for needed an AQ270 (perhaps AQ268) to stop the recommended 25 PHBL from running lean through the mid-range. This totally reflected my independent testing!
LambrettaMarky - please excuse me for talking PHBL, which doesn't relate to your PHBH requirement, but it continues a topic that others have introduced.
Other Dellorto models - I have experienced PHBH, VHSA, VHSB and VHSH Dellortos running atomisers as small as 260 diameter (but ranging up to 270), even when using the same 2.5mm diameter needles, so wonder how much the efficiency of model, speed of air flow through the carb (even different slide design influence for same size) or other factors may be influencing atomiser size requirement?
LambrettaMarky - You are doing the right thing by starting rich and working leaner, testing along the way.
Good luck and keep the thread going as those responding have a wealth of experience.
coaster wrote:Chrikey you dont hang about MarkGood choice with the 30 PHBH and loads of good advice so far. I probably mentioned that I also have a GT240 as well as the GT200 version I was riding to Marlow. JL3 will suit the 240, I had one on a TS1225 and Ron Moss Avanti but neither would rev past 6.5k RPM. I have a BGM Clumman on the 240 which suits its tall gearing but I fitted a Franspeed Race to the 200 and also tried an ADS3 both of which were brilliant, very slight loss of torque at low revs but bags of torque where you need it for overtaking.
Someone mentioned 'trenching' for the GT240 but it just requires a minimal amount of metal to be removed from the casingusing a dremel or die grinder. 1mm deep and 10mm approx. I did mine in about 10 minutes using an angle drinder through the mag housing side but that was a bit brutal tbh
December 22 by KTM Marky, on Flickr
JL3 LHS by KTM Marky, on Flickr
JL3 RHS by KTM Marky, on Flickr
JL3 Silencer by KTM Marky, on FlickrAdam_Winstone wrote:If you bike has the correct GP plastic / nylon throttle wheel in the headset then a worthwhile modification is to drill or melt a suitably small hole through the back of it, along the cable's direction of travel so that the long 'universal' inner cable can run through, then cut and soldered to stop strand fraying. The benefit is that it is easy to source and replace cable inner as/when necessary.
PHBH Cable by KTM Marky, on Flickr
PHBH Cable Routing by KTM Marky, on Flickr
New Throttle Pull Thru Hole 2 by KTM Marky, on Flickr
New Throttle Pull Thru Hole 1 by KTM Marky, on FlickrAdam_Winstone wrote:Yep, that's exactly the throttle modification that I was trying to put into words (lol). I'm glad it made sense.
Brake cable clearance by KTM Marky, on Flickr
Skimmed disc by KTM Marky, on Flickr
Disc Skim by KTM Marky, on Flickr
Fork 1 by KTM Marky, on Flickr
Fork 2 by KTM Marky, on Flickr
Indian Spring by KTM Marky, on Flickr
Stop Removal by KTM Marky, on Flickr
8mm Balls by KTM Marky, on Flickr
10.11.24 by KTM Marky, on FlickrUsers browsing this forum: No registered users and 87 guests
