Covboy wrote:those figures seems low - my gt240 makes 22-24hp and 20lb/ft torque at 6500rpm - 30mm dellorto and TSR pipe.
thats straight out the GT box, not fettled.
I'd add that i think its a great kit too.
Toddy wrote:Been running my GT240 for the last 5 years just on first oversize done a lot of trouble free miles on it good kit you may need to trench the casing for the crank , as for Italian , Indian I’ve had both not a lot of difference riding wise
Cgt75b wrote:Have you considered the new RB 240 which doesn’t require the case being modified, just something else to look at/consider.
Good luck in your decision making.
LambrettaMarky wrote:Thanks & I do have Sticky's books.
I'd do the work over the winter, so not concerned about being off the road as such.
missing lynx wrote:LambrettaMarky wrote:Thanks & I do have Sticky's books.
But do you have the Kit book with the brown cover?
Nudger wrote:missing lynx wrote:LambrettaMarky wrote:Thanks & I do have Sticky's books.
Sticky's Kit Book would be a good read for you (it's an interesting read for anyone really). I have a GP with an AF Rayspeed Stage 4 barrel & solid mount 30mm carb, I think this is exactly what you'd be looking for. You could always source it via CamLam I'm sure. Alternatively, in the warmer months come along to some LCGB events and talk to people over a pint. Always a great source of real world experience.
Adam_Winstone wrote:You really need to figure out what you already have as many, probably most, Indian GP200s will already have the SIL Stg IV factory tuned barrel. In which case you're probably half way there already! You may also find that you currently have the SIL big bore exhaust or a clubman fitted, which again would get you on the way to what you are looking to achieve.
As others have said, the Indian GP200 should be at least as fast as the Italian GP200. If the Indian one is factory spec' then, as mentioned above, it should already benefit from ported cylinder and performance exhaust, resulting in more BHP and a faster top speed.
One step you could go for before committing to any kit is to determine what you have and to consider swapping the standard 22mm carb for a 30mm PHBH Dellorto, which you would need if you decide to go for the GT kit in the future. This combo of what you may already have + 30mm carb is used by many and meets the requirements of said users.
NB: You're lucky to live close to Cambridge Lambretta as they're a great bunch and would be able to advise you on what you already have and then make suggestions as to which may you might want to go, then be able to supply said parts.
Having just ridden over 1200 miles to/from 5-Nations in Fort William with one of my riding group being on a SIL IV with clubman and 30mm PHBH, I know exactly how well these go. Indeed, I knew anyway as this is a combo that I and many in my club have used for years. That said, the GT kits are excellent too... but another level of performance again. It all depends what you want.
Good luck, welcome to Lambretta and take care with anything you do.
Adam
Adam_Winstone wrote:Don't forget that you will need a manifold and throttle cable to suit this new carb. FYI - The carbs are available in rubber mount or solid mount options and you'll need a rubber mount version (and manifold) so that the carb is compatible with the GT kit, if you decide to upgrade in the future.
Let Cambridge know exactly what you are looking to do so that they can ensure that you leave with any sundries that you might need; carb rubber, clips, gasket, JETS, etc.
Users browsing this forum: Baidu [Spider], Google [Bot] and 77 guests
