Pompeydave wrote:Hi all, bike dyno run done on Saturday by Paul Jolliffe in Pompey.
The 25PHBL has the following spec:
Atomiser: AQ 266
Choke: 60
Main: 95
Pilot: 53
Needle: D22 on the top clip
It was also found to have a 30 slide, which was the cause of the low down slow running issue and over richness.
Tom Palmer was there and he thankfully supplied a spare 40 slide. Paul found that the choke cable was slightly tight and wasn’t always seating properly when turned off. The solution is to fit an elbow and slightly longer cable.
Also, he’s recommended that the jetting is about right with the main being slightly on the rich side of perfect for safer motorway running. He’s also suggested that I change the timing from 16BTDC to 19, and if it’s still is a big boggy low down, to try a 45 slide and then an AQ265 atomiser. Key point being to try one thing at a time.
Anyway, it instantly rides way cleaner low down with the 40 slide. Choke elbow and longer cable ordered and the timing change is up next. I’ll report back with progress.
Pompeydave wrote:Hi all. Anyone know what to do next when trying to upload a photo of the dyno run I’m getting a message saying:
‘Sorry, the board attachment quota has been reached’.
Toddy wrote:Pompeydave wrote:Hi all. Anyone know what to do next when trying to upload a photo of the dyno run I’m getting a message saying:
You need to use a photo hosting sight like this
https://postimages.org/
cdn imagesUsers browsing this forum: Bing [Bot] and 47 guests
