I hope this isn’t going off topic
alex_hughes wrote:I hope this isn’t going off topic, Nsaints was referring to a standard disc brake and obviously substituting brake lever for clutch lever is referring to standard drum brakes, which of course can also be reverse pulled.
For reference, a standard Italian lever, a Spanish lever, and a standard clutch lever.
That the clutch lever bends the wrong way is worrying me! And I’m not sure how you’d cable it up, because it’s narrower at the end. I guess there’s a way
Mr B sells shorter clutch levers, same length as Spanish, but also bending the wrong way.
The Spanish lever is going to get a trial on my S1 tomorrow. Didn’t even know I had it!
dickie wrote:I think it's also worth remembering what storkfoot(?) said in another thread, that his reverse pull drum suffered badly from heat fade in the mountains of somewhere or other. I tend to just knock about locally, but if I'd done the c2c last weekend as intended, I wonder how well I'd have coped coming down from hardknott?
Storkfoot wrote:Fast n Furious wrote:It could be that the actuator rentention circlip is weaker on the SX and is flexing outward more under braking, giving you a spongy, full travel brake feel.
A simple visual inspection of the clip whilst pulling in the lever will confirm if this is a contributor. If the lever moves but the actuator doesn't, then the springing is in the cable
I would advise against using stainless circlips here as these do stretch. Just use regular carbon spring steel ones.
Make sure that the circlip groove is completely free of paint, so the circlip can sit in the groove as far down as possible. (I use a little wire brush attachment on my Dremmel)
The circlip groove does suffer over time on Disk brakes that have seen their fair share of service. The constant eccentric force applied to the groove wall by the circlip, causes the outer wall of the circlip groove to bevel. The more it bevels, the more the clip will "spring" laterally under braking.
There is a solution to redressing this issue but it involves a milling machine.
A modern quality front brake cable these days is 2.5mm and well worth fitting. The bigger the cable the less is the stretch.
Over the years I've heard many myths as to reverse pull or not. The only reason I can see to favour reverse pull is because the cable is slightly shorter and has less bends in it therefore making it more efficient.
What’s the remedy with the milling machine please, F&F?
I’ve had a circlip pop off under braking. The circlip, I later discovered, was substantially thinner than the spare one I replaced it with but I can’t be sure that was the only reason it came off. The disc hub is an original Italian with virtually no paint left in the groove.
Users browsing this forum: Google [Bot] and 57 guests
