by jonoy » Sun Aug 18, 2024 6:19 pm
Can anyone recommend a good strong rear hub.
I was going to buy a scootopia version but dealer states current version won’t
work with sip rims.
jonoy on Sun Aug 18, 2024 10:49 pm, edited 1 time in total.
jonoy
by gizmo » Sun Aug 18, 2024 8:54 pm
I have one ready to go for paint. I wasn't aware they won't fit sip rims. Had the Mk 1 and it did
gizmo
by jonoy » Sun Aug 18, 2024 10:48 pm
It’s on Camlam website
jonoy
by ULC Soulagent » Tue Aug 20, 2024 9:54 am
Even the Scootopia rear hubs are warped from new as I found out ffs
Very hard these days to find a good un so I can’t recommend any.
ULC Soulagent
by gizmo » Tue Aug 20, 2024 11:44 am
I know they are expensive but are the octopus hubs any truer and rounder
gizmo
by Cgt75b » Tue Aug 20, 2024 5:00 pm
I’m running a Uni, no complaints.
by rogscoot » Wed Aug 21, 2024 10:48 am
I also have a new Uni hub and it seems to be fine.
rogscoot
by Toddy » Wed Aug 21, 2024 7:05 pm
Ive been using UNI hubs for a while no issues so far
by Nigel. S » Wed Aug 21, 2024 8:09 pm
Uni here. I had a hub that wouldn't accept any rims from one supplier.
Nigel. S
by Fast n Furious » Wed Aug 21, 2024 10:10 pm
gizmo wrote:I know they are expensive but are the octopus hubs any truer and rounder
The Octopus hub has a splined drive rather than the more conventional taper lock drive. Consequently, they do run true and concentric without having to apply any fettling to get them running true, but you will need the layshaft and hub nut that go with it if going down this deep pocket route.
by gizmo » Thu Aug 22, 2024 7:34 am
Fast n Furious wrote:gizmo wrote:I know they are expensive but are the octopus hubs any truer and rounder
I don't suppose the unique layshaft takes away gearbox choice.?
gizmo
by jonoy » Tue Aug 27, 2024 8:24 pm
Ended up buying a uni hub that sip rims sit correctly on.
jonoy
Users browsing this forum: Google [Bot] and 68 guests
