Rear hub
Rear hub
Postby jonoy » Sun Aug 18, 2024 6:19 pm
Can anyone recommend a good strong rear hub.
I was going to buy a scootopia version but dealer states current version won’t
work with sip rims.
jonoy
Re: Rear hub
Postby gizmo » Sun Aug 18, 2024 8:54 pm
I have one ready to go for paint. I wasn't aware they won't fit sip rims. Had the Mk 1 and it did
gizmo
Re: Rear hub
Postby jonoy » Sun Aug 18, 2024 10:48 pm
It’s on Camlam website
jonoy
Re: Rear hub
Postby ULC Soulagent » Tue Aug 20, 2024 9:54 am
Even the Scootopia rear hubs are warped from new as I found out ffs :evil:
Very hard these days to find a good un so I can’t recommend any.
ULC Soulagent
Re: Rear hub
Postby gizmo » Tue Aug 20, 2024 11:44 am
I know they are expensive but are the octopus hubs any truer and rounder
gizmo
Re: Rear hub
Postby Cgt75b » Tue Aug 20, 2024 5:00 pm
I’m running a Uni, no complaints.
Re: Rear hub
Postby rogscoot » Wed Aug 21, 2024 10:48 am
I also have a new Uni hub and it seems to be fine.
rogscoot
Re: Rear hub
Postby Toddy » Wed Aug 21, 2024 7:05 pm
Ive been using UNI hubs for a while no issues so far
Re: Rear hub
Postby Nigel. S » Wed Aug 21, 2024 8:09 pm
Uni here. I had a hub that wouldn't accept any rims from one supplier.
Nigel. S
Re: Rear hub
Postby Fast n Furious » Wed Aug 21, 2024 10:10 pm
gizmo wrote:I know they are expensive but are the octopus hubs any truer and rounder
The Octopus hub has a splined drive rather than the more conventional taper lock drive. Consequently, they do run true and concentric without having to apply any fettling to get them running true, but you will need the layshaft and hub nut that go with it if going down this deep pocket route.
Re: Rear hub
Postby gizmo » Thu Aug 22, 2024 7:34 am
I don't suppose the unique layshaft takes away gearbox choice.?
gizmo
Re: Rear hub
Postby Fast n Furious » Sun Aug 25, 2024 1:43 am
Not at all.
Re: Rear hub
Postby jonoy » Tue Aug 27, 2024 8:24 pm
Ended up buying a uni hub that sip rims sit correctly on.
jonoy
Users browsing this forum: Baidu [Spider] and 30 guests
