Model d legshield edge rubber and caps
Postby mm man » Sun Jun 16, 2024 12:28 pm
I think I’m having a bit of a moment :?
I was looking to get some replacement rubber trim and end caps for my D legshields something is telling me it’s different than standard S3 but can’t seem to be able to find it anywhere?
Any help or links much appreciated.
mm man
Re: Model d legshield edge rubber and caps
Postby jbcollier » Thu Jun 20, 2024 3:33 am
Doesn't use rubber floor runners, just metal. Cambridge, and I'm sure others, have them:
https://www.lambretta.co.uk/index.php?cPath=60_83
jbcollier
Postby mm man » Thu Jun 20, 2024 10:55 pm
Hi thanks for your reply
Sorry if my first post wasn’t very clear I’m looking for the rubber beading that fit around the outside edge of the legshield not the alloy runners that fit to the floor section .
I see from your link Cambs Lambretta sell a set of beading for a LD is this the same for a D ?
The stupid thing is I have a set fitted to my other D legshields sure I got it from a parts fair around 20years ago and for the life of me I can’t remember what the seller said .
If this link works is the same as this one
Thanks again for your time .
https://www.handh.co.uk/auction/lot/114 ... 57074&sd=1
mm man
Postby jbcollier » Fri Jun 21, 2024 4:45 pm
Wow, cool scoot.
The D did not come with any leg shield edge trim. You can buy bulk trim and caps from some scooter parts shops like SIP or Scooter Centre.
jbcollier
Postby mm man » Mon Jun 24, 2024 11:24 pm
Thanks very much for your time and input I followed the link for Cambs Lambretta and this will do the job
https://www.lambretta.co.uk/product_inf ... ts_id=9162
Thanks again
mm man
Return to Pre 57
Users browsing this forum: Baidu [Spider] and 7 guests
