by Littlewheels » Thu Jun 20, 2024 9:28 pm
Does anyone know how to tell the difference between a GP (brass bush) rear sprocket and an Li/SX/TV one? I know one is hardened so that it can withstand bearings being run inside it but is there a size difference? And can I run a bushed one in a Li set up?
Littlewheels
by dickie » Fri Jun 21, 2024 3:14 am
The 2 piece ones are hardened for roller bearings.
And yes, you can use the bushed type in an LI set up; I only use this type, as do many others.
Users browsing this forum: Baidu [Spider] and 88 guests
