+1Fast n Furious wrote:Personally, I fail to see the point in them.
The original gear is perfectly satisfactory if set up and maintained properly.
gizmo wrote:+1Fast n Furious wrote:Personally, I fail to see the point in them.
Storkfoot wrote:Did Oiltek ever put the rear hydraulic set up into production?
As for Tino’s internal Hydra rear set up, I am unsure whether I have ever seen that for sale, let alone heard of anyone who has one fitted.
With the rear set up, I can’t see beyond the hassle of even taking a wheel off, never mind setting it up properly.
tim_mason wrote:i have had three scooters with rear discs and like anything else its a learning curve with setting them up ,but worth it in the end and look trick when fitted.
gizmo wrote:I'm sure Oiltek did produce them. I remember one being on display on their shop counter many moons ago. They looked good. I'm sure if you really wanted one Paul at Oiltek would do you one.
tim_mason wrote:gizmo wrote:I'm sure Oiltek did produce them. I remember one being on display on their shop counter many moons ago. They looked good. I'm sure if you really wanted one Paul at Oiltek would do you one.
The ones i have used are the early type from Pat in Saigon , these came with an indian made 'RAMP' rear hub which lasted about 400 miles second one lasted the same , so i machined a good quality hub , sorted. Second one i binned the foot brake bracket and welded a bracket to the frame , much neater ,
I am fitting the same to a side project but with a rear set brake pedal with the slave cylinder fitted to the back plate .
eaststandjohn wrote:tim_mason wrote:gizmo wrote:I'm sure Oiltek did produce them. I remember one being on display on their shop counter many moons ago. They looked good. I'm sure if you really wanted one Paul at Oiltek would do you one.
Users browsing this forum: No registered users and 31 guests
