Avanti ex box
Avanti ex box
Postby Micky67keane » Thu Apr 25, 2024 4:41 pm
Going to be fitting an Avanti ex box and 17t front sprocket at weekend(currently on Bgm v.2 and 16t).
Will I need to up my main jet?
Im running a 28mm PHBH with 118 main jet
All info appreciated.
Micky67keane
Re: Avanti ex box
Postby Rich Oswald » Thu Apr 25, 2024 5:49 pm
Plug chops are the best indicator of that but you could go up a couple of sizes to be safe and work your way back down.
Re: Avanti ex box
Postby Micky67keane » Thu Apr 25, 2024 9:03 pm
Rich Oswald wrote:Plug chops are the best indicator of that but you could go uo a couple of sizes to be safe and work your way back down.
Nice 1,thank you
Micky67keane
Re: Avanti ex box
Postby bookertmgs1 » Fri Apr 26, 2024 8:39 am
what top end have you got on ? Gear box ? Crownwheeel ?
Why increase the front sprocket size ? whats the intended result ?
You are potentially changing 3 things all at the same time - which adds a degree of complication if the results arent what you expect
bookertmgs1
Re: Avanti ex box
Postby hullygully » Fri Apr 26, 2024 10:33 am
bookertmgs1 wrote:what top end have you got on ? Gear box ? Crownwheeel ?
+1
Re: Avanti ex box
+1
Re: Avanti ex box
Postby Micky67keane » Fri Apr 26, 2024 1:30 pm
Thanks for the replies.
Going off another thread about raising my top speed a little(and wanting a new exhaust) Im changing to an ex box,going to a 17t sprocket which should give me the extra mph required(currently 62gps).At the moment its screaming at top end.l,so going to a 17t would help to reduce that too?
Any and all advice greatly accepted.Thank you
Micky67keane
Re: Avanti ex box
Postby Micky67keane » Fri Apr 26, 2024 1:31 pm
I have an RT195 and 46t crownwheel with pacemaker box.
Micky67keane
Re: Avanti ex box
Postby Toddy » Fri Apr 26, 2024 7:39 pm
I would try the exhaust first before changing anything else you will know then if you need to alter the gearing
Re: Avanti ex box
Postby bookertmgs1 » Mon Apr 29, 2024 10:31 am
Ok - with the Pacemaker gear box & 17T would make it very similar to LI150 & 16T which should suit the kit.
Dont forget you are likely to need a new chain too.
On a standard RT Kit you should expect another 5mph flat out - but nothing revolutionary
bookertmgs1
Re: Avanti ex box
Postby Micky67keane » Wed May 08, 2024 6:21 pm
Thanks for the replies,should have changed this by now but hopefully THIS weekend!
Micky67keane
Re: Avanti ex box
Postby Micky67keane » Mon May 27, 2024 3:30 pm
Only just got round to doing this.Seems to pull alot better now,2nd and 3rd have a more useful range and 4th isn't screaming it's head off.
67mph gps speed which is liveable(for now..)
Thanks for all replies/advice,gratefully recieved.Cheers,Mick
Micky67keane
Users browsing this forum: Google [Bot] and 37 guests
