m-tech settings
m-tech settings
Postby a-teamlambretta » Tue Apr 09, 2024 6:40 pm
I'm sure it's been covered........
Setting for the following.
Mugello 225 early version slightly tuned. Squish set at 0.95mm
Jl3 exhaust
Gearing
19/47
Late Indian gp200 gearbox
Carb phbh 30mm
Mid weight Indian flywheel
Thanks in advance.
Simon.
a-teamlambretta
Re: m-tech settings
Postby Rich Oswald » Wed Apr 10, 2024 11:22 am
Hi Simon, I have exactly the same set up on my GP but with a Taffy MK 4, so very similar. I have a 5 speed in now but had a GP200 box with 19/46 when I had it dynoed at Chis'. Martin fitted me an M Tech and set it at position D.
Hope this helps,
Re: m-tech settings
Postby a-teamlambretta » Thu Apr 11, 2024 6:33 pm
Rich Oswald wrote:Hi Simon, I have exactly the same set up on my GP but with a Taffy MK 4, so very similar. I have a 5 speed in now but had a GP200 box with 19/46 when I had it dynoed at Chis'. Martin fitted me an M Tech and set it at position D.
Hope this helps,
Many thanks Rich, will give a try .
Cheers Simon.
a-teamlambretta
Re: m-tech settings
Postby Rich Oswald » Fri Apr 12, 2024 9:38 am
Hope this helps,
Cheers Simon.
No problem Simon, good luck,
