Toot wrote:
I suppose the primary question here is why and how are copper sintered disc brake pads supposedly more superior to standard disc pads? (Especially considered that the vast majority of Lambretta disc brakes are never going to get anywhere near to the working temperature of a racing two wheeled machine going around a race track?)
Scooterlam wrote:Had thought of that but the fixed pad only touches the end of a 6mm stud.
I'll try on the piston side,
It's a hydrolic convention btw.
dickie wrote:After you removed and cleaned the pads, did the squealing disappear for the first few applications? If it did, then it's probably contamination getting onto them. It can take the tiniest amount for this to happen.
Also, is your disc drilled or plain? Drilled ones can help to keep the pad surfaces slightly roughed up and keep squealing down.
Hard braking can help too, whereas light frequent braking tends to polish up the surfaces. Maybe the slide pins are a little tight, so the disc is rubbing on the pads all the time and causing them to glaze? That last point is pure conjecture, I've never come across that being a problem, but a thought just popped into my head.
Rich Oswald wrote:Mine squealed but then stopped after I reverse pulled it.
Storkfoot wrote:Rich Oswald wrote:Mine squealed but then stopped after I reverse pulled it.
Interesting. Presumably, that is because there is extra force immediately applied between the pads and disc
missing lynx wrote:Have you given them a good spray with brake cleaner? Squeaking can be caused by contamination on the pads or disk also is the anti rattle clip working properly? If the disk isn't able to float under centrifugal force it will rub(squeak) the static pad
Users browsing this forum: Google Adsense [Bot] and 11 guests
