Jetting
Jetting
Postby pg42 » Tue Mar 26, 2024 5:04 pm
If i fit a 22mm carb to my Standard SX200 engine, what jetting should i use? Should i use a ram filter and forget the airbox? Will a 22mm manifold fit a standard cylinder without modification to the inlet port?
pg42
Re: Jetting
Postby missing lynx » Tue Mar 26, 2024 8:29 pm
I would start by jetting it the same as a GP 200 you can run it through a std air box you just need to take the baffle out the scoop and the funnel out the neck of the air box
Re: Jetting
Postby pg42 » Tue Mar 26, 2024 9:45 pm
Thanks for that
pg42
Return to Carburettors
