RT 195 Reedvalve?
RT 195 Reedvalve?
Postby Micky67keane » Fri Mar 08, 2024 9:52 pm
I've got a RT195 with 28 phbh and a BGM box(v2),at the moment I'm getting about 62mph(gps).
I'm thinking of maybe getting it reedvalved with a touring tune.
What sort of speed increase would I be looking at?
Thanks in advance
Micky67keane
Re: RT 195 Reedvalve?
Postby dickie » Sat Mar 09, 2024 10:08 am
That sounds a little low to me. Maybe your gearing could be the solution if top speed is all you want to increase.
What gearbox and sprockets are you running.
But as a more direct answer to your question, I have a rt225 with Reed and Ron Moss pipe and although I have no idea what my top speed is, it's as much as I want and definitely a good bit more than 62mph.
Postby Micky67keane » Sat Mar 09, 2024 7:43 pm
Thanks Dickie,
Im using a Pacemaker box with 16/46 sprockets which gives me I think 5.29 fd.95% of my riding is two-up.It pulls well with us both on but just feel I need a little more top end.
Micky67keane
Postby Knowledge » Sat Mar 09, 2024 10:57 pm
Micky67keane wrote:I've got a RT195 with 28 phbh and a BGM box(v2),at the moment I'm getting about 62mph(gps).
Thanks in advance
Reed valves are not a route to more speed. They have several advantages but they are a effectively a restriction in the inlet tract and therefore do not increase air/fuel flow into the engine.
As others have suggested, you might need to look elsewhere for the tardy performance. Have you had it dyno’d? It might give you a phew extra mph by improving the carburation, but you are not too far from what I would expect for a GPS top speed for your set-up.
Postby Micky67keane » Sun Mar 10, 2024 2:06 pm
Thanks for the advice,I haven't had it dyno'd,the jetting was suggested by the guy who built the engine and all seems ok,no dead spots pulls well.
Just a little disappointed at top end,should have stuck with the Lammy speedo it was touching 70.Lol
Micky67keane
Postby missing lynx » Sun Mar 10, 2024 4:46 pm
Are you getting 62 mph 2's up? With your fdr you will need to rev to about 8000 revs to get 70. Gearing, tuning is a compromise you could change things to make it do 80 solo on the flat but it will die on hills once you're 2's up. There is a rose tinted view of lammy top speeds but if it's 62 2's up that not bad
Postby Micky67keane » Sun Mar 10, 2024 4:53 pm
Ye,62 two up,doesn't really do anymore on my own.
Micky67keane
Postby Rich Oswald » Mon Mar 11, 2024 11:20 am
62, two up is a good top speed for your set up. A bit better exhaust, ie Avanti Ex Box and maybe a change of gearing could help a lot.
Postby Micky67keane » Mon Mar 11, 2024 9:17 pm
Rich Oswald wrote:62, two up is a good top speed for your set up. A bit better exhaust, ie Avanti Ex Box and maybe a change of gearing could help a lot.
Thanks for the advice,I was looking at an ex-box so may go down that route.
Micky67keane
Postby dickie » Mon Mar 11, 2024 10:10 pm
Micky67keane wrote:Thanks Dickie,
I've got AF 4speed close ratio and 20/47, so FDR is 4.7.
Higher capacity than yours and a avanti pipe. I'm the opposite, 95% of my riding is solo. But I reckon you could comfortably go to 17 tooth front.
Postby Micky67keane » Mon Mar 11, 2024 11:24 pm
Think I may give this a go.
Thank you to all who replied and all the advice.
Micky67keane
Users browsing this forum: Bing [Bot] and 55 guests
