Storkfoot wrote:I can vouch for this Chiselspeed conversion. I have it on an LTH 7 plate and the clutch is as soft as on my standard TV175. It’s not cheap but it works.
https://www.chiselspeed.co.uk/store/product/CST845465B
I tried the AF easy clutch but gave up. It made the difference between a slipping clutch and a dragging clutch to be almost non existent. I could probably have persisted with every available permutation but I lost patience and took it off.
scarkey wrote:Hi,
I am currently recovering from a broken left hand, grip is not so good.
I am looking at solutions to make the use of the clutch easier eg AF Rayspeed Easy Clutch etc.
What have others used as a answer to this problem
TIA
Clarkie
York SC
Den08 wrote:After two Brocken fingers and wrist screws plate etc thought that’s it for me.
Rb250 Af uni easy clutch with Lth clutch new sip clutch cable, two finger clutch now absolutely
Spot on, best of luck for your recovery.
Cgt75b wrote:scarkey wrote:Hi,
TIA
Clarkie
York SC
Have you tried Derek Dowlings easy clutch?
Storkfoot wrote:Den08 wrote:After two Brocken fingers and wrist screws plate etc thought that’s it for me.
On the AF Easi Clutch, what notch did you use for the clutch cable trunnion?
trotsky wrote:Cgt75b wrote:scarkey wrote:Hi,
TIA
Clarkie
York SC
Agreed. Would definately recommend. Just put one on Wendy's TS1....superb bit of kit.
trotsky wrote:Hi Rich,
Strange? We tried the AF set up & i couldn't get to work at all, but with Derek's Mk4 version no probs, i measured it before & after & it has the same cable travel with the same clutch & dogleg lever, just a quite noticeable lighter feel at the lever?
Weeksey has one on, which seem's to work great, so that's what prompted us to try one on Wendys... tho not rallied it yet for a proper testing, so far so good.
L111amo wrote:I tried the earlier versions & couldn’t get them to work, seen the latest version, different take on it, any experts that think it work any better ?
