jonoy wrote:Get a CTEK charger and leave it connected when not using scooter
Storkfoot wrote:I have been monitoring this battery and the other two Batteries I have on other Lambrettas. This battery was down to 9v in a week, or so, whereas the other two I have have stayed at around 12 or 13v. Given that neither of my other DC battery Lambrettas have indicators, I suspect the indicator system, possibly the flasher unit, is draining it.
I have bought one of the CTEK battery chargers, as recommended by Jonoy. These chargers have a function to analyse the battery itself and whether it is capable of holding charge. It shows that this SIP battery is okay.
So, when this scooter is not in regular use, I’ll continue to keep the CTEK connected.
Storkfoot wrote:I did think of that, Paul. The CTEK has a handy plug in connector which makes it very easy to use. Basically, just take the panel off and plug straight in.
I also think there may be a way of using a multimeter to identify where the drain is actually from
L111amo wrote:Surely the relay wouldn’t have any power unless key is on?
Storkfoot wrote:L111amo wrote:Surely the relay wouldn’t have any power unless key is on?
Just a cut out switch but, yes, the way I have wired up these “home brew” indicators is to have them as a separate circuit powered by the battery. What I mean is that the battery positive is wired to the flasher unit through a fuse.
coaster wrote:Storkfoot wrote:L111amo wrote:Surely the relay wouldn’t have any power unless key is on?
The way you have it wired, you will have that drain all the time which is why I mentioned that you will need a switch to disconnect auxilary corcuits. Ive had to do it on both of mine as the SIP speedo, Gamma unit take power and would drain the battery if I didnt ride it or a while. 2ma is a very small drain though but 24 hours a day, week on week adds up. you could put an inline switch in the battery feed inside your tool box, gled or even velcro'd to the inside of the door
Users browsing this forum: Google [Bot] and 78 guests
