Panel hook
Panel hook
Postby stephena » Mon Aug 10, 2020 9:01 pm
I have seen a shortened panel hook for sale a while ago for series 2 for you to cut panel hook and replace with a removable one to make swapping rear wheel easier. Anyone have contact details please. Thanks.
stephena
Re: Panel hook
Postby gaz_powell » Mon Aug 10, 2020 9:46 pm
Re: Panel hook
Postby neily03 » Mon Aug 10, 2020 11:11 pm
Is there some sort of solution available for earlier series 3’s? The spring makes removing the rear rim a right pain...
neily03
Re: Panel hook
Postby Warkton Tornado No.1 » Mon Aug 10, 2020 11:24 pm
neily03 wrote:Is there some sort of solution available for earlier series 3’s? The spring makes removing the rear rim a right pain...
I could be wrong, but thought the one piece S3 panel spring can effectively swing down like the GP's. Isn't there a top clip that can be rotated (if not too tight) to allow that to happen? Both panels need to be off or unclipped to allow the spring to rotate.
Re: Panel hook
Postby neily03 » Mon Aug 10, 2020 11:30 pm
Unfortunately not, the top clip is welded in place so prevents the spring swinging down
neily03
Re: Panel hook
Postby Warkton Tornado No.1 » Tue Aug 11, 2020 8:51 pm
Oh! :?: That shows that it is some time since I assembled my SX!
Sorry about that, but I will check my panel spring retention method. The fact that any modification to what you have would be hidden by the registration plate is food for thought though.
On GP's I always connect the two springs together centrally with rubber hose to sync them & act as a buffer to the frame. As mentioned previously, it means both panels need removing to access the wheel more easily.
Re: Panel hook
Postby shane BBoys » Wed Aug 12, 2020 12:46 am
Regarding the S2 panel hook try Jon Betts safe you eBay price
shane BBoys
Re: Panel hook
Postby Tractorman » Wed Aug 12, 2020 8:20 am
shane BBoys wrote:Regarding the S2 panel hook try Jon Betts safe you eBay price
JB Fabrication panel hooks are an excellent replacement if you are having problems removing the wheel.
Re: Panel hook
Postby HxPaul » Wed Aug 12, 2020 8:29 am
Re: Panel hook
Postby stephena » Thu Aug 13, 2020 9:53 am
Thanks for replying all ordered via eBay last night.
stephena
Re: Panel hook
Postby burnside » Tue Aug 18, 2020 11:06 am
In case anyone else was also looking to purchase, if you have a S1 or S2 these really are a godsend, it is cheaper to buy direct from Jon Betts (JB Fabrication) on FaceBook, I paid £15 for mine whereas eBay is £18.50. Basically you are then not paying for eBay and PayPal fees on top.
burnside
Re: Panel hook
Postby Soulsurfer » Mon Nov 13, 2023 8:24 am
Resurrecting this thread… Does anyone make these removable hooks in stainless steel?
Soulsurfer
Re: Panel hook
Postby Leotech » Mon Nov 13, 2023 10:29 am
The newer s3 frames didn't have the hook at the top centre, you could just cut it off then the spring thing swings down.
Leotech
Users browsing this forum: No registered users and 60 guests
