TS1 with left hand inlet manifold
Postby a-teamlambretta » Mon Nov 06, 2023 9:47 pm
Anyone using a left hand inlet manifold on a TS1 cylinder?. I don't want to hack the battery tray off my series 1. Is there enough clearance ect ?.
Cheers Simon.
a-teamlambretta
Re: TS1 with left hand inlet manifold
Postby Knowledge » Tue Nov 07, 2023 8:22 am
Sticky has one on his TS1 240 and Superhooper on here has one too on his pretty standard TS1 225.
Both engines are good.
Postby Storkfoot » Tue Nov 07, 2023 8:48 am
Postby jonoy » Tue Nov 07, 2023 2:09 pm
I have a LTH left side manifold on my TS 1 on my GP
All good
jonoy
Postby superhooper » Tue Nov 07, 2023 6:34 pm
Used offset cones to give more clearance. All good
Regards Super
superhooper
Postby Norrie Bodge » Tue Nov 07, 2023 8:33 pm
jonoy wrote:I have a LTH left side manifold on my TS 1 on my GP
All good
+1
Using a skimmed reed block (by half) & 3mm reed packer
no issues
Norrie Bodge
Postby a-teamlambretta » Tue Nov 07, 2023 9:37 pm
Thanks to all for the info... will get one ordered.
Cheers Simon.
a-teamlambretta
Postby Leotech » Wed Nov 08, 2023 9:29 am
Again see other TS1 exhaust post, I also asked Ben about a left hand manifold as my bike is UK from new with a battery tray which I don't wish to hack off, He said same as he did about the box pipes and PHBH carbs.
With a PHBH and an Avanti type box pipe the left hand manifold is not noticeable, But if you go for full on flat slide and a high revving expansion pipe etc, you will notice a drop in performance.
Leotech
Postby a-teamlambretta » Thu Nov 09, 2023 12:15 am
I have just ordered this one from sip
https://www.sip-scootershop.com/en/prod ... m_40821200
a-teamlambretta
Postby Leotech » Mon Nov 13, 2023 10:32 am
I should have said AF Ben has them in stock.
Leotech
Postby al pushpak » Wed Jan 03, 2024 10:25 am
will one of these fit a Monza 225? cheers
al pushpak
Postby a-teamlambretta » Wed Jan 03, 2024 1:57 pm
al pushpak wrote:will one of these fit a Monza 225? cheers
Yes ...I was using an imola manifold on the ts1 prior to going left hand manifold.
Cheers Simon
a-teamlambretta
Postby al pushpak » Wed Jan 03, 2024 2:03 pm
cheers
al pushpak
Users browsing this forum: Solid Air and 2 guests
