Borgo
Borgo
Postby Littlewheels » Fri Sep 22, 2023 8:52 am
Are original Borgo pistons forged or cast?
Littlewheels
Re: Borgo
Postby Fast n Furious » Fri Sep 22, 2023 11:42 am
Cast.
Re: Borgo
Postby Storkfoot » Fri Sep 22, 2023 1:32 pm
I am no expert, by any means, but I am assuming that you are interested in Borgo pistons as they were originally supplied, three ring and original fitment.
From what I read, there are arguments for and against forged pistons.
But, if you are running an old Borgo piston for a near standard set up, you should be fine.
Re: Borgo
Postby Littlewheels » Fri Sep 22, 2023 10:54 pm
Thanks for the replies. So if it’s cast does anyone know what clearance there should be between the piston & the bore? I’ve read that there needs to be less clearance on a cast piston compared to that of a a forged piston.
Littlewheels
Users browsing this forum: No registered users and 85 guests
