martyn dwane wrote:I know AF and SIP make Tubelss rims,and they are different , i now see FA Italia, and BGM also make them are they all different ? Any others, whats the pro`s and cons of the differnt ones ?
TIA
Toddy wrote:martyn dwane wrote:I know AF and SIP make Tubelss rims,and they are different , i now see FA Italia, and BGM also make them are they all different ? Any others, whats the pro`s and cons of the differnt ones ?
TIA
The AF ones fit on standard studs and I believe are harder to get tyres on , SIP ones come with longer studs and seem the preferred choice
Rich Oswald wrote:Toddy wrote:martyn dwane wrote:I know AF and SIP make Tubelss rims,and they are different , i now see FA Italia, and BGM also make them are they all different ? Any others, whats the pro`s and cons of the differnt ones ?
TIA
I have both and Chiselspeed have never had issues putting tyres on. That doesn't mean to say that others haven't had a problem.
gp200ts1 wrote:i have lambretta re-store split tubeless (no longer made) and a set of gori split tubeless with another set on backorder. no faffing around trying to find someone to fit tyres when i can now do it myself. highly recommended despite poor italian delivery dates.
Scooterslag wrote:gp200ts1 wrote:i have lambretta re-store split tubeless (no longer made) and a set of gori split tubeless with another set on backorder. no faffing around trying to find someone to fit tyres when i can now do it myself. highly recommended despite poor italian delivery dates.
Interesting, one of the main things that puts me off tubeless is finding someone local who can fit the tyres easily and without knackering the ( expensive) rims. I think Pinasco make split tubeless as well. Paul
gp200ts1 wrote:Martyn, they are on backorder with VE spares. Best price I could find and as I’m in no rush I can manage the wait.
Fast n Furious wrote:I always soften my tyres first by putting the tyre in a steel box along with my 2kw fan heater, turning the tyre periodically to heat it evenly. I like to get it so that I can just handle it with bare hands.
Tyre bead soap is essential and plenty of it.
The only tool I use is a mallet to tap the bottom of the tyre into the well of the wheel as much as possible. If the tyre is soft enough, then the top of the beading will fold over the rim using your hands and knees. (I've seen too many tyres and rims damaged through the use of tyre levers. I would strongly advise against their use!)
After fitting, If the tyre doesnt expand out onto the rim, then you can use a ratchet strap around the circumference of the tyre to persuade the tyre beading out toward the rim. A high volume compressor is virtually essential. ( The one that plugs into your cig lighter socket just ain't gonna cut it) As soon as the beading begins to grip the rim, remove the strap and inflate to the desired pressure. Recheck the pressure after the tyre has cooled down.
Some fitters remove the tyre valve during the initial inflation proceedure. I've never found this neccessary myself, but I suppose if your compressor capacity is limited, then this may very well help.
martyn dwane wrote:gp200ts1 wrote:Martyn, they are on backorder with VE spares. Best price I could find and as I’m in no rush I can manage the wait.
thanks.
martyn dwane wrote:martyn dwane wrote:gp200ts1 wrote:Martyn, they are on backorder with VE spares. Best price I could find and as I’m in no rush I can manage the wait.
thanks.
Ive messaged two dealers that have them listed as out of stock on their website about back ordering 2 , No reply from either , must be nice to be so busy that you cant reply.Guess i`ll stick to what Mr Innocenti made.
