by martyn dwane » Fri Jul 21, 2023 1:33 pm
friend of mine has a SIP vape fitted and their speedo, he also runs a sat nav occasionally.he wants to fit a small battery , to charge from the DC trickle charge facility. What size battery would you recommend ?
martyn dwane
by ULC Soulagent » Sun Jul 23, 2023 3:56 am
5-7amp alarm battery is fine and compact
ULC Soulagent
by Knowledge » Sun Jul 23, 2023 8:31 pm
Yuasa have a really good specification pdf on their website. It has sizes, shapes, voltage, amp-hour and even the position of the terminals.
Very helpful.
by martyn dwane » Mon Jul 24, 2023 2:17 pm
thanks , info passed on.
martyn dwane
by coaster » Sun Jul 30, 2023 7:45 pm
Knowledge wrote:Yuasa have a really good specification pdf on their website. It has sizes, shapes, voltage, amp-hour and even the position of the terminals.
Very helpful.
Also, bike batteries have proper screw terminals rather the spade connectors used on alarm batteries which in my experience develope high resistance over time.
by dickie » Sun Jul 30, 2023 9:18 pm
coaster wrote:Knowledge wrote:Yuasa have a really good specification pdf on their website. It has sizes, shapes, voltage, amp-hour and even the position of the terminals.
Very helpful.
Any battery will benefit from some grease on the terminals. Don't worry too much about phrases like 'dielectric grease', almost all greases are dielectric, but it doesn't matter if it is or isn't. The important thing is that it stops corrosion.
by coaster » Thu Aug 03, 2023 1:58 pm
dickie wrote:coaster wrote:Knowledge wrote:Yuasa have a really good specification pdf on their website. It has sizes, shapes, voltage, amp-hour and even the position of the terminals.
Very helpful.
True, but the problem I find is that the male and female connector contact surfaces wear enough to cause high resistace. This might be (in my case) due to the batteries on both my scoots being in a box near the rear wheel.
Users browsing this forum: Baidu [Spider], Google [Bot] and 68 guests
