Timing
Timing
Postby srx600 » Sun Jun 25, 2023 9:46 pm
What be the effect of only running 7 degrees of advance. I realised earlier that when connect my timing strobe to the battery its already set to 10 degrees advance. Since I have been using it to set the timing against marks on the flywheel housing, I think that means I have been running with 7 degrees of advance.
Would this cause poor low-mid range performance, or poor performance at higher revs.
srx600
Re: Timing
Postby Fast n Furious » Mon Jun 26, 2023 12:45 am
Most likely, it would cause poor everything!
Re: Timing
Postby srx600 » Mon Jun 26, 2023 10:01 am
I was working on the basis that most of the variable timing boxes retard the timing at higher revs, so presumably if the timing was already retarded it might run ok at higher revs and poorly at lower revs
srx600
Re: Timing
Postby hullygully » Mon Jun 26, 2023 1:05 pm
7Degs advance on what timing marks bud?
do you mean 7degs+ on the std 23/21 degs BTDC?
Re: Timing
Postby srx600 » Mon Jun 26, 2023 2:29 pm
hullygully wrote:7Degs advance on what timing marks bud?
On TDC mark. So 7 degrees BTDC. I was trying to set to 17 but the strobe already had 10 degrees when powered on (and I didnt realise) so I think I was setting to 7 degrees.
srx600
Re: Timing
Postby hullygully » Mon Jun 26, 2023 5:30 pm
good job you noticed it then bud :shock:
Users browsing this forum: Google [Bot] and 46 guests
